shocks like a full coilover?
does anyone make a shock that adjusts on the lower shock like a full coilover setup does? i figure it seems like a good diea, but does anyone manufacture it? I assume it would provide a lot a shock travel.
here the blue part adjusts. this leaves the shock n spring at a set height right?
does any company like tokico or koni make a shock that adjusts like this?
Modified by laocivic at 10:10 AM 1/29/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laocivic »</TD></TR><TR><TD CLASS="quote">does anyone make a shock that adjusts on the lower shock like a full coilover setup does?</TD></TR></TABLE>
Huh?
Lots of companies make threaded-body dampers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">i figure it seems like a good diea, but does anyone manufacture it?</TD></TR></TABLE>
What do you think you just posted a picture of?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I assume it would provide a lot a shock travel.</TD></TR></TABLE>
It's not what you think. Coilovers like that actually have a fixed stroke and are intended to work with a narrow range of spring rates.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">here the blue part adjusts. this leaves the shock n spring at a set height right?</TD></TR></TABLE>
Adjusting that effectively shortens or lengthens the overall length of the damper body. It does not affect the stroke at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">does any company like tokico or koni make a shock that adjusts like this?</TD></TR></TABLE>
Koni makes various dampers with fully threaded bodies, but you will have to fab up your own threaded lower mount. Why would you want to do that though?
Huh?
