b16 swap
Old Jan 28, 2008 | 05:47 PM
HiProfile's Avatar
Default b16 swap
Hello. I'm wondering about info on swapping a B16 into a EF chassis.
Could someone provide a link, not to the General FAQ page, but to a page which actually explains what is needed? I can't seem to find the right link in the FAQ, so I'm very confused.
A moderator just locked a similar topic and give the FAQ link, but there are NO LINKS in the FAQ on how to swap a b-series into the <U>EF chassis</U>. It shows a link for the 5th Gen civic, which is of no help to a 4th Gen owner.
Old Jan 28, 2008 | 07:04 PM
hughesl's Avatar
Default Re: b16 swap (HiProfile)
https://honda-tech.com/zerothread?id=1193782
Dude, It is further down in the FAQ. If you pan down there is plenty of information on this swap. Most likely this post will also get locked. Typically if your first post gets locked then you make another with the same question the result will be the same.....
Anyway check the FAQ a little more, I attached one link from the FAQ for you to get you started.
kid-crx
Apr 29, 2005 05:40 PM
ek9 ferio
Sep 12, 2003 09:36 PM
WhatThaFrig
May 27, 2003 05:08 PM
