injector wont fire...
Old Jan 28, 2008 | 03:47 PM
corked1260's Avatar
Default injector wont fire...
i cant not figure out why the injectors will not fire..... any help would be appreciated in case it helps its a 92 si hatch
Modified by corked1260 at 5:08 PM 1/28/2008
Old Jan 28, 2008 | 03:59 PM
ekpunker's Avatar
Default Re: injector wont fire... (corked1260)
This may make me sound like an extreme smart-***, but are the injectors getting an adequate amount of fuel?
Old Jan 28, 2008 | 04:08 PM
corked1260's Avatar
Default Re: injector wont fire... (ekpunker)
no it dosnt make u sound like a smart *** hahah i asked my self the same thing today a few times haha ... yes they are gettingn enough fuel but they wont spray...
Old Jan 28, 2008 | 04:18 PM
ekpunker's Avatar
They sound clogged badly.
In the past, I've just run some fuel injector cleaner through my fuel system to prevent that, but I'm not sure how to clean them once they are clogged... Try to confirm this first though.
Old Jan 28, 2008 | 04:28 PM
corked1260's Avatar
thanks i will look in this tomm....... anyone have any other ideas i can check
Old Jan 28, 2008 | 04:32 PM
ranlvsbianx15's Avatar
Default Re: (corked1260)
you're sure your fuel pump is working right? the fuse ok?
have you changed your fuel filter yet?
or yeah, might be just the injectors clogged.
Old Jan 28, 2008 | 04:36 PM
corked1260's Avatar
yes I'm sure the pump is working and i don't think that the filter is clogged...... but i took off the fuel line after the fuel filter and turned the car on for a second and fuel was pumping out..... so that can only mean its working
Old Jan 28, 2008 | 04:39 PM
Crx Jimmy's Avatar
are they the stock injectors or did you do a swap?
Old Jan 28, 2008 | 04:41 PM
corked1260's Avatar
nope they are the stock injectors...... the car was running fine and all of the sudden stopped working one day..... it will run wiht eather sprayed in it..... but will die when i burns off all the eather
Old Jan 28, 2008 | 05:09 PM
corked1260's Avatar
anything????
Old Jan 29, 2008 | 01:48 AM
corked1260's Avatar
bump
Old Jan 29, 2008 | 03:12 AM
RIZOBIZERT's Avatar
Use a 'node' tester to make sure they are getting signal. DO NOT USE A TEST LIGHT. No signal, trace your electrical to find your answer. Oh yes, hours of fun with wiring. Good luck.
Old Jan 29, 2008 | 11:19 AM
corked1260's Avatar
i will be checking it wiht a node light as soon as i get one..... and i was told today that even if i ahve some fuel pressure if i dont have enough it still wont ifre is this true i have to pressure test it also now..
Old Jan 29, 2008 | 01:03 PM
corked1260's Avatar
i know somone here knows that easy question
Old Jan 31, 2008 | 12:41 PM
RIZOBIZERT's Avatar
Yes, you need the correct amount of fuel pressure. Your car is computer controlled, so the injector only opens for a specified time. As a result, if you have low fuel pressure you won't get enough gas into the combustion chamber and that magical stoichiometric equation just won't happen. Good luck.
pjr710
Apr 3, 2010 05:59 PM
Slyfox_racer
Sep 16, 2007 01:04 PM
Slyfox_racer
Sep 13, 2007 03:17 PM
crnimacak
Apr 21, 2006 10:11 PM
Backk InTheDA
Feb 24, 2005 03:52 PM
