gauge cluster drama
Old Jan 28, 2008 | 01:58 PM
JDM_SOHC's Avatar
Default gauge cluster drama
so im drivin along n hit a big chain in the road an my rpm, mph, an engine temp needles all die... gas gauge still works.. any ideas? turn signals r out too....
Old Jan 28, 2008 | 02:00 PM
Archidictus's Avatar
Unceasing Measure
Default Re: gauge cluster drama (JDM_SOHC)
Have you looked under your hood to see if there's any damage or busted fuses? Maybe I should use my mental abilities to diagnose exactly what happened without having to leave my home. Hold on...
Did it work? No? Okay, then go out and take some pictures of the underside and engine bay of your car and get back to us.
Old Jan 28, 2008 | 02:02 PM
Syndacate's Avatar
Where did this chain make contact with the car?
Old Jan 28, 2008 | 02:03 PM
JDM_SOHC's Avatar
Default Re: gauge cluster drama (Archidictus)
well I appreciate the prompt response the smart *** **** aint needed dude.. im on the interstate pulled over, **** just happened 2 minutes ago...
Old Jan 28, 2008 | 02:06 PM
Syndacate's Avatar
Probably just knocked a wire loose.
Check your fuses (both boxes) and tell us where the chain made contact with the car.
Old Jan 28, 2008 | 02:09 PM
JDM_SOHC's Avatar
Default Re: (Syndacate)
it was all rolled into a lil ball in middle of my lane an I swerved to not make contact but hit it anyways a the second I hit it I heard Boom n all my gauges died except fuel an my car still runs fine but I don't wanna risk a 2hr drive on a wish ya know... just seein if anyone might kno what to check... obd1 d15b in ej2... if that helps...
Old Jan 28, 2008 | 02:14 PM
Syndacate's Avatar
Default Re: (JDM_SOHC)
You can't find a place underneath where the chain made contact?
Old Jan 28, 2008 | 02:21 PM
JDM_SOHC's Avatar
honestly dude I dnt think it hit anything.. just felt like a big *** pothole...
Old Jan 28, 2008 | 05:20 PM
I Shot 50 Cent's Avatar
Hopefully something was just knocked loose from the impact and not actually destroyed.
And from hitting something under the car, there's not many electrical things that could have been hit, yanno? My guess is that you hit it so hard you literally knocked a fuse loose. I'm not sure why the gas guage still works and nothing else, but since the turn signals are out too....Just do a quick check in the fuse boxes for the appropriate fuses and hope for the best. Check the underhood fuse box as well, and see if any wires are literally ripped and hanging anywhere. Good luck brotha!
Old Jan 28, 2008 | 07:38 PM
JDM_SOHC's Avatar
Default Re: (I Shot 50 Cent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Shot 50 Cent &raquo;</TD></TR><TR><TD CLASS="quote">Hopefully something was just knocked loose from the impact and not actually destroyed.
And from hitting something under the car, there's not many electrical things that could have been hit, yanno? My guess is that you hit it so hard you literally knocked a fuse loose. I'm not sure why the gas guage still works and nothing else, but since the turn signals are out too....Just do a quick check in the fuse boxes for the appropriate fuses and hope for the best. Check the underhood fuse box as well, and see if any wires are literally ripped and hanging anywhere. Good luck brotha!</TD></TR></TABLE>
preciate it my brotha, an yezzir u called this one... fuggin 10amp fuse in kickpanel fusebox was shot, threw in one for my domelight into that spot an BLAM everything worked.. haha crazy **** if u ask me, but than again hittin that chain felt almost like the equivelent of hitting hillary clinton with my car haha, rough impact status haha.. it was one of the chains from the hanging door on a dumptruck that hold the door in place with the big pin an ****... to that and to you...
Old Jan 29, 2008 | 04:47 PM
Steven.'s Avatar
sorry that dykes raided your topic.. glad u fixed it.. dam cheap fuses expletive alot of **** up
Old Jan 29, 2008 | 06:44 PM
Glad everythings workin bud. Always a good feeling being able to help someone out.
Old Jan 30, 2008 | 06:44 AM
JDM_SOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Shot 50 Cent &raquo;</TD></TR><TR><TD CLASS="quote">Glad everythings workin bud. Always a good feeling being able to help someone out. </TD></TR></TABLE>
Hell yeah dude, thanks again...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steven. &raquo;</TD></TR><TR><TD CLASS="quote">sorry that dykes raided your topic.. glad u fixed it.. dam cheap fuses expletive alot of **** up</TD></TR></TABLE>
yeah they tend to ***** themselves as readily available as they can lol... thanks dude..
90si-rex
Jul 7, 2014 02:17 PM
xsicrx120
Sep 23, 2009 02:00 PM
aznnikeballer887
May 5, 2008 11:08 PM
krytykalintentions
Apr 1, 2007 12:16 PM
