h22 swap distributor question
Old Jan 27, 2008 | 11:11 PM
hotrodaccord's Avatar
Default h22 swap distributor question
I have a 97 accord with a 93 jdm h22, my distributor went bad, the one that came on the engine has an internal coil.... I've researched majestic honda, distributor king and few other places. all I can find is one with a external coil. I don't really want to change my harness to run a external coil any advise or do I have no choice.
Old Jan 27, 2008 | 11:58 PM
Default Re: h22 swap distributor question (hotrodaccord)
I know it's a accord but figured you guys would know more about the engine
Old Jan 28, 2008 | 12:11 AM
Acidcrakker's Avatar
Well if you swapped over for the USDM Harness during your swap, you wouldnt have to change anything
Old Jan 28, 2008 | 03:29 AM
MoonScryer's Avatar
Search for "jdm prelude distributor" on Ebay gives:
http://cgi.ebay.com/ebaymotors...ZWDVW
Distributor King FTW.
Old Jan 28, 2008 | 06:49 AM
Giant_Bean's Avatar
Default Re: (MoonScryer)
http://www.napaonline.com/mast...-+New
Old Jan 28, 2008 | 09:56 AM
mgags7's Avatar
Default Re: h22 swap distributor question (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Well if you swapped over for the USDM Harness during your swap, you wouldnt have to change anything</TD></TR></TABLE>
He used his accord harness, which is set up to use internal coil. You can't even use a jdm harness w/o doing some serious wire extending anyways.
No need to be a smart ***.
If you just need coils, you can get the part for 92-97 civics I know for sure. I recommend replacing the whole thing if at all possible, though.
Old Jan 28, 2008 | 03:08 PM
slamdlude's Avatar
Default Re: h22 swap distributor question (mgags7)
I have a jdm internal coil dizzy for an H22 lying around if it will work for you. I took it off my swap to run the external coil dizzy off my H23. I'll let it go cheap if you can use it. PM me for details.
Broken Devil
Oct 18, 2005 11:13 AM
93R33Lude
Mar 1, 2004 04:08 PM
Ddogz15
Aug 1, 2003 09:35 PM
H22CIVIC
Aug 9, 2001 05:36 PM
