Throttle body questions
I've got a jdm b16a with a type r intake manifold and stock t/b. will an STR 68mm t/b make any difference? Also what do I do about the FITV. I did some research and did not find the answer I was looking for having the ITR manifold.
yeah it will make some differences at mid rpm and high rpm range. i have a jdm b16 and i am running a 68mm skunk2 throttle body with oem itr intake manifold but i have that manifold bored to 68 mm, b16 stock TB is 60mm and stock itr TB is 62mm
Upgrading to a 68mm throttle body is not going to yield the results you're looking for...unless the car is tuned for the extra air AND can make efficient use of it, you're just wasting your money. IMO, there are better ways to spend that money and time....if you want a more detailed description, go to the FI forums and search "throttle body tech" and you'll find my elaborate description of why or why not this would be a good/ bad choice
1baddturbosi
Feb 18, 2007 07:36 PM
Nextelbuddy
Apr 12, 2004 01:55 PM
