Suspension & Brakes Theory, alignment, spring rates....
top hat bushing for Koni Yellows
Old Jan 27, 2008 | 07:03 PM
See Are X's Avatar
Default top hat bushing for Koni Yellows
I picked up some used Koni Yellows for my civic. I just tried to install the rears and then I realized that the shaft on the shock does not fit into the bushing on my top hats. What do I need to do/buy?
Old Jan 27, 2008 | 07:32 PM
ThoseDarnKids's Avatar
Default Re: top hat bushing for Koni Yellows (See Are X)
The Koni shaft has a larger diameter than the factory shocks. You need the larger metal collar that fits in the rubber bushings.
New Koni's come with this collar, so whoever you bought them from didn't give them to you. Did you just buy the rears or did you get all four and you had the proper collars for the fronts?
Old Jan 28, 2008 | 04:26 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">What do I need to do/buy?</TD></TR></TABLE>
http://www.koni-na.com/apparel...ory=P
The 8041 series pin hardware kit.
Old Jan 30, 2008 | 05:38 AM
pnthr30's Avatar
Default Re: top hat bushing for Koni Yellows (Targa250R)
I had this same issue and ran ALL OVER TOWN trying to find something else that would work - long and short of it is that despite my best efforts, I could not find anything that fit properly (I tried calling hardware stores, speed shops, dealers, pipe fitting places, and even stopped at a few machine shops to see if they had anything the right size or could hone out a slightly larger one)......at the end of my exercise, I ordered them from KONI and got exactly what I needed.
Cliff Notes: Just call KONI now and order the kit and save yourself some time.
Good luck.
Old Aug 20, 2024 | 05:38 AM
RaiLS's Avatar
Veteran: Army
They came with the tophats. I sleeve pictured came with the Koni yellows.
jlh22179tx
Suspension & Brakes
Oct 20, 2006 11:39 AM
johnzm
Suspension & Brakes
Feb 8, 2006 11:29 AM
Jaydeep
19
Jul 16, 2004 04:03 PM
DOHCTOR
Dec 26, 2002 09:14 PM
paulyman
May 17, 2002 08:13 PM
