Wtf? Tranny swap question
Old Jan 27, 2008 | 12:57 PM
AJZerick's Avatar
Default Wtf? Tranny swap question
Ok I posted a topic about this about a week ago but I just realized something...
when doing an auto to manual swap...dont you need a Clutch Slave and hardline?
I mean I guess you dont since if you look in the faqs at that AOL homepage where it talks about changing to manual...it dosnt mention a clutch slave...so is it nessasary or what?
Old Jan 27, 2008 | 01:24 PM
wiZCo's Avatar
Stouts 'n' Scotch
Are you using a hydro trans? If not, then no.
If you are you should have a cable-to-hydro kit that includes everything you'll need. (I assume this is a cable car?)
Also, you failed to mention which engine, car and transmission.
Old Jan 27, 2008 | 01:25 PM
gibsanez's Avatar
Default Re: Wtf? Tranny swap question (AJZerick)
Yeah, when swapping a transmission into a chassis that is designed for a cable clutch, you need a bunch of hydraulic transmission parts
But seriously, If you're swapping a hydro trans in your EF, it's much easier just to buy a cable to hydro bracket. If you're swapping to a cable trans, all you need is a manual pedal cluster and a clutch cable.
Old Jan 27, 2008 | 01:50 PM
AJZerick's Avatar
Im talking about an Si tranny into DX
but thanks
because i read about tranny swap into a 240sx and they had to install a clutch slave
Old Jan 28, 2008 | 05:01 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (AJZerick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJZerick &raquo;</TD></TR><TR><TD CLASS="quote">Im talking about an Si tranny into DX
but thanks
because i read about tranny swap into a 240sx and they had to install a clutch slave</TD></TR></TABLE>
So... I guess you learned that what works for one car probably doesn't for another, then?
Next time, try to get instruction for YOUR car.
Old Jan 28, 2008 | 05:19 PM
AJZerick's Avatar
Yea,my friend just moved to Texas,and he had this DX auto CRX. and he said $200 and its yours so I bought it.
mikeyleed
Jun 24, 2014 04:36 PM
streetsold6teeny8
May 13, 2010 04:17 PM
Maxboost00
Jan 17, 2007 07:28 PM
synner
Aug 6, 2006 12:09 PM
vtec_powah
Aug 1, 2006 11:46 PM
