Gsr camshafts in b16 head.
Old Jan 27, 2008 | 11:03 AM
Jix99Si's Avatar
Default Gsr camshafts in b16 head.
if i install gsr camshafts in a b16 head, can i go with aftermarket valve springs, retainer, and valves from Brian Crower?
the duration from stock b16 camshaft to Gsr camshfts are longer but the gsr cams have more lift, is this suitable for a ideal turbo setup?
Old Jan 27, 2008 | 11:21 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Gsr camshafts in b16 head. (Jix99Si)
they work great with a turbo application and you can use your stock valve train if you don't want to upgrade
Old Jan 27, 2008 | 11:37 AM
H.A.R.T B18C1EG6's Avatar
Default Re: Gsr camshafts in b16 head. (Throwdown)
gsr cams are fine and also stock valvetrain. But if you want to upgrade then go for it
KillAHonDa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jix99Si &raquo;</TD></TR><TR><TD CLASS="quote">if i install gsr camshafts in a b16 head, can i go with aftermarket valve springs, retainer, and valves from Brian Crower?
the duration from stock b16 camshaft to Gsr camshfts are longer but the gsr cams have more lift, is this suitable for a ideal turbo setup?</TD></TR></TABLE> GSR cams will work great with aftermarket , i myself am using gsr cams supertech valves, springs, and ret / turbo setup
Old Jan 27, 2008 | 12:09 PM
Jix99Si's Avatar
Default Re: Gsr camshafts in b16 head. (KillAHonDa)
you recommend Brian Crower parts for the valve train? they are affordable and seem like great parts
TomTread
Apr 30, 2008 10:43 AM
SupraRXZ
Apr 20, 2007 05:18 AM
Rhythm
Dec 21, 2005 01:58 PM
AZTEKEF9
Jul 13, 2004 07:16 PM
