Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Inside the V6 Automatic Transmission
Old Jan 27, 2008 | 09:23 AM
Jim Truett's Avatar
Default Inside the V6 Automatic Transmission
It's a 1999 V6 Acura CL tranny. It's basically just like a constant mesh manual tranny with hydraulic clutch packs to select the gears. This transmission started slipping badly on a 2nd and 3rd shift. The 2nd gear clutches were worn down to the adhesive that bonds the friction material to the clutch plate. Normal thickness was .079", and these measured in at .055-.050". The standard free play in the clutch packs is between .015"-.045". With six discs worn between .024"-.029", that combined for about .160" total free play, and made the shifts very harsh.
With the end cover removed:
With the mid case removed:
1/2 clutch drum with clutches removed:
Worn 2nd gear clutches:
Installation of new friction and steel:
Old Jan 27, 2008 | 11:32 AM
veggiemaster's Avatar
Default Re: Inside the V6 Automatic Transmission (Jim Truett)
Awesome visuals.
How long did the trans removal and clutch pack rebuild take you? Also, I would think this same trans is in the same model year TL-S?
Old Jan 27, 2008 | 03:46 PM
YeuEmMaiMai's Avatar
Default Re: Inside the V6 Automatic Transmission (veggiemaster)
there is no 99 TL type S TL type S was 2002-03 and 2007+
TL type S has a beefed up auto to handle the extra power
Old Jan 27, 2008 | 04:54 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster &raquo;</TD></TR><TR><TD CLASS="quote">Awesome visuals.
How long did the trans removal and clutch pack rebuild take you? Also, I would think this same trans is in the same model year TL-S?</TD></TR></TABLE>
Removal was three hours. The rebuild was about a total of 12, but that was with cleaning everything and replacing all of the orings and some bearings. This was a '99, so it is similar to the accord V6.
Old Jan 27, 2008 | 05:13 PM
3.0L v6 CL is the exact same drive line as the accord for 98-02. There are no physical changes between the two.....other than DIS and mode updates to the 4spd to TRY and correct the problems
Jim Truett
Nov 16, 2014 10:44 AM
bg2128506
Acura TL, RL & ZDX
Jul 15, 2013 11:23 AM
green98civic
13
Jun 28, 2003 10:13 AM
crxaddikt
16
Apr 4, 2002 05:25 AM
Comptech98GSR
Jul 5, 2001 07:55 PM
