Racing Sparco N1 help!!
Old Jan 27, 2008 | 07:24 AM
MrWoohoo's Avatar
Default Racing Sparco N1 help!!
I've just bought some Racing Sparco N1 wheels today 15x7 4x100 et+38, got home done a test fit on my EG8 & EJ2.
Unfortunately the R40 Kics (M12 x P1.50) lugnuts I have don't fit into the holes and I don't have any others to try.
Does anyone know what lug nuts will fit these wheels? also do I really need to fit spigot rings on the back of these rims, if I do does anyone know where I can source some from?
Thanks
Old Jan 27, 2008 | 08:22 AM
toyomatt84's Avatar
Sanji
You'll need a "tuner style" lug nut. One which requires a key to remove and attach. I've used a few different styles, and there are plenty out there.
I don't know what a "spigot ring" is, but I'll assume you mean a hub centric ring (used to align the wheel's hub diameter with the car's hub diameter). They're found at a few online stores like 1010tires.com.
Old Jan 27, 2008 | 02:19 PM
wishingiam's Avatar
Default Re: (toyomatt84)
I got these from gorilla (on the right) it's a 1/2in longer shank and fits into the hole and the conical area seats where it should.
The lugs in the pic on the left are probably similar to what you have now, and either don't fit into the hole or only thread on a couple of threads.
Any wheel shop should be able to help you get the ones on the right, I don't have any part numbers.
Old Jan 27, 2008 | 04:21 PM
jesselee's Avatar
Default Re: Racing Sparco N1 help!! (MrWoohoo)
https://honda-tech.com/zerothread?id=2169433
Old Jan 28, 2008 | 07:22 AM
MrWoohoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">You'll need a "tuner style" lug nut. One which requires a key to remove and attach. I've used a few different styles, and there are plenty out there.
I don't know what a "spigot ring" is, but I'll assume you mean a hub centric ring (used to align the wheel's hub diameter with the car's hub diameter). They're found at a few online stores like 1010tires.com.</TD></TR></TABLE>
Thanks , I've only ever known them referred to as spigot rings, now I know why I got confused looks when I tried asking for them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phuckyou &raquo;</TD></TR><TR><TD CLASS="quote">The lugs in the pic on the left are probably similar to what you have now, and either don't fit into the hole or only thread on a couple of threads.
Yeah someone else I know suggest Gorilla lugs, but said to measure first to be sure to get the right ones, thanks for the reply dude.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jesselee &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=2169433</TD></TR></TABLE>
Thanks.
Think I may have found a proper set of sparco lug nuts for this wheel.
CustomEJ6
May 26, 2007 08:58 PM
Usagi Yojimbo
Jan 4, 2006 06:22 PM
Andrea_Aunie
Jun 25, 2002 10:05 PM
Andrea_Aunie
Jun 25, 2002 03:17 PM
