proper bung size for radiator fan switch?
Old Jan 27, 2008 | 05:38 AM
kommon_sense's Avatar
Default proper bung size for radiator fan switch?
I need to relocate my radiator fan switch. Can anyone tell me what size bung is needed for the fan switch for a b/d/k-series motor? I need an aluminum weld-on bung to relocate it to the bottom of an aluminum radiator.
Trying to avoid having to drain the coolant system to size and order the bung.
Modified by kommon_sense at 9:51 AM 1/27/2008
Old Apr 9, 2008 | 06:37 AM
Default Re: proper bung size for radiator fan switch? (kommon_sense)
Just a follow up. The radiator fan switch uses the same size fitting as the o2 sensors. It is an 18mm x 1.5 . I found an aluminum one on ebay. Got it welded in, everything is working great.
SunriseSunset
Apr 15, 2017 04:43 PM
FSRslug
Mar 16, 2011 07:59 AM
VTEC_PRODUCTION
Aug 17, 2009 04:20 AM
ihavenocar
Sep 16, 2008 10:45 PM
ItalynStylion
Aug 8, 2004 11:11 PM
