TW: 92 H22 Prelude CLEAN!!! ACCEPTING OFFERS (NEW ENGLAND AREA)!!!
Old Jan 26, 2008 | 09:23 PM
Mr.60trim's Avatar
From: What Business is it of yours where Im from Friendo
Default Great Project Car!!!!!!!!!!!!!!!!
<U>ENTERTAINING OFFERS AROUND 3.7K</U>
I'm NOT parting pieces out.
This Prelude has A LOT of tasteful NEW mods...Great project car! Buyer can use them on his/her own Prelude, or part-out on his/her own and make the money back.
This happens to be my failed attempt at a turbo project.
CAR WAS NEVER BOOSTED...IT NEVER GOT TUNED. The car currently is back to all-motor. The car runs, but has a difficult time starting possibly due to the timing being way off.
<U>Car Info/History</U>[*]1992 Prelude SI (245K on chassis) - Purchased 5/29/04[*]1994 JDM H22A motor & tranny (Hmotorsonline.com) w/ (approx 55K miles currently)[*]No Major dents or Rust. Will need a paintjob soon.[*]Never been in an accident (Clean Title) - Can provide carfax report[*]Interior is immaculate!!! (No rips, scratches, burns, etc AT ALL)
<U>Motor</U>[*]1994 H22A (Hmotorsonline.com) approx 55Kmi (...was not daily driven)[*](220psi each cyl - Compression test done on 11/18/07)[*]Oil change every 3k miles. Mobil1 synthetic 10w 30 along w/ Mobil1 oil filters[*]Supertech head - Racing valves Stainles steel valves, Titanium retainers - Done by Qu at (DSG) (LESS THAN 70MILES!!!)[*]***Dent Sport Garage - A reputable shop in MA***[*]<U>JDM TRANSMISSION - HAS NO GRINDS AT ALL!!!!</U>[*]New Skunk2 70mm TB (Bored by DSG)[*]New Skunk2 Intake Manifold (Port-Matched 70mm by DSG)[*]New XTD stage 4 clutch (less than 50 miles usage - still needs to be broken in)[*]New Fidanza 8lbs aluminum flywheel (less than 50 miles)[*]New Skunk2 adjustable camgears[*]New Hondata thermal intake manifold gasket[*]New Megan stainless steel header[*]New Vibrant flat black straight through muffler[*]New Walbro fuel pump 255LPH[*]FAL slim fan 1250cfm (Bought used)[*]New Mishimoto half radiator[*]New Odyssey PC680 mjt slim battery[*]New AEM alternator pulley[*]New OEM Crankshaft pulley[*]New OEM headgasket[*]New OEM Valve cover gasket[*]New exhaust manifold gasket[*]New alternator belt[*]All New seals & o-rings in valve cover[*]Custom painted valve cover w/ camgear moon-cuts[*]New Jegs valve cover breather catch can setup (-10AN fittings & stainless steel lines)[*]New ECT sensor (not installed)[*]New Vtec pressure switch sensor[*]New TPS sensor (not installed)[*]Megan oil pressure gauge[*]NGK 9mm spark plug wires[*]NGK v-power spark plugs (6-range)
(I will include the stock Throttle body, and Intake manifold)
<U>Suspension & Brakes</U>[*]Skunk2 adjustable coilovers[*]KYB 4-way adjustable shocks[*]Megan Upper front & rear strut bars[*]Megan lower tie bar[*]Brembo cross-drilled & slotted rotors[*]PFI traction bar[*]17" ADR GT-Sport Rims (painted black - silver lugs w/ key lock)[*]Fronts: Yokohama Parada Spec-2 tires[*]Rears: Continental ContiSportContact tires [*](All tires 215/45/R17) *90% left on all 4 tires* (tirerack.com)
<U>Cosmetics & Misc</U>[*]New NRG Leather steering wheel, quick release, short hub & lock[*]JDM black housing 1pc headlights (No scratches, peeling or blemishes)[*]Custom tailights (clear signals)[*]Accord-R Front lip[*]OEM Accord rear lip[*]New Clifford Alarm[*]6000K HID kit (Not installed - New in box) - Will include if buyer wants
<U>The Bad</U>[*]CEL codes: ECT, TPS...(I have both sensors ready to go...I have no time to install them)[*]The car has a difficult time starting on a cold start...(This might be due to the ECT sensor faulty ?)[*]Car runs...but somewhat laggy. Needs to be tuned (possibly due to larger skunk2 TB & IM)[*]Paint...Typical paint nick nacks nothing major. However the rear bumper may need to be repainted. [*]Cosmetic...Recently tapped the rear bumper backing up in the garage causing some rear bumper paint damage. (I can provide pictures)[*]Rust...nothing major. Very slight hint of it around the typical above the rear fender area.[*]Front lip has a small unnoticable crack in the lower left area. (Super glue fix)[*]Brake pads may need to be replaced soon.
DON'T BE AFRAID TO PM ME OR CALL ME ANYTIME IF YOU HAVE ANY QUESTIONS OR CONCERNS. IF YOU WANT MORE PICS JUST ASK AND I WILL PROVIDE THEM AS SOON AS I CAN.
CELL# (617) 301-3043
Be a gentleman and BUMP if you look. Thanks
Modified by Mr.60trim at 7:46 AM 3/14/2008
Modified by Mr.60trim at 6:40 PM 3/18/2008
Old Jan 26, 2008 | 09:24 PM
Mr.60trim's Avatar
Default Re: TW: 92 H22 Prelude CLEAN!!! ACCEPTING OFFERS (NEW ENGLAND AREA)!!! (Mr.60trim)
<U>Pics - Exterior - Disregard the FMIC</U>
<U>Interior - Only ones I have thus far...Will be posting more soon!</U>
<U>SuperTech Head - Built By Qu @ DSG - Less than 70 miles!!!</U>
<U>Stock Bottom end</U>
<U>Engine Bay</U>
<U>6000K HIDs</U>
Modified by Mr.60trim at 8:47 PM 3/5/2008
Old Jan 27, 2008 | 07:14 AM
Mr.60trim's Avatar
Morning bump!
Old Jan 27, 2008 | 12:29 PM
Mr.60trim's Avatar
PMs replied
Old Jan 27, 2008 | 04:17 PM
Mr.60trim's Avatar
Default Re: TW: 92 H22 Prelude CLEAN!!! ACCEPTING OFFERS (Mr.60trim)
Night bump
Old Jan 28, 2008 | 06:46 AM
Mr.60trim's Avatar
Good Morning!
Old Jan 28, 2008 | 12:07 PM
Mr.60trim's Avatar
ttt
Old Jan 29, 2008 | 08:22 AM
Mr.60trim's Avatar
Up for more offers!!!!
Old Jan 29, 2008 | 02:01 PM
Mr.60trim's Avatar
Evening bump
Old Jan 30, 2008 | 08:46 AM
Mr.60trim's Avatar
Shoot me some more offers people!!!
Old Jan 30, 2008 | 06:05 PM
Mr.60trim's Avatar
Night Bump
Old Jan 31, 2008 | 02:43 AM
Mr.60trim's Avatar
I need this gone!!!! Car is just sitting!
Old Jan 31, 2008 | 02:15 PM
Mr.60trim's Avatar
Bump for more offers!
Old Jan 31, 2008 | 03:56 PM
Mr.60trim's Avatar
CAR IS BEING SOLD AS A PARTS ONLY CAR!!!
Old Feb 1, 2008 | 06:53 AM
Mr.60trim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.60trim &raquo;</TD></TR><TR><TD CLASS="quote">CAR IS BEING SOLD AS A PARTS ONLY CAR!!!</TD></TR></TABLE>
Bump
Old Feb 1, 2008 | 09:22 AM
Mr.60trim's Avatar
Default Re: PARTS-ONLY CAR... ACCEPTING OFFERS!!! (Mr.60trim)
PMs returned
Old Feb 1, 2008 | 12:30 PM
Mr.60trim's Avatar
bump it up!
Old Feb 2, 2008 | 07:24 AM
Mr.60trim's Avatar
yes yes yall!
Old Feb 2, 2008 | 02:29 PM
Mr.60trim's Avatar
Old Feb 2, 2008 | 09:06 PM
Mr.60trim's Avatar
Owl bump!
Old Feb 3, 2008 | 07:41 AM
Mr.60trim's Avatar
Superbowl Sunday Bump!
Old Feb 4, 2008 | 03:44 AM
Mr.60trim's Avatar
Up!
Old Feb 4, 2008 | 10:11 AM
Mr.60trim's Avatar
afternoon bump
Old Feb 4, 2008 | 03:59 PM
Mr.60trim's Avatar
bump
Old Feb 5, 2008 | 03:32 PM
Mr.60trim's Avatar
alright...let's try this again
