auto or manual ecu how do I find out?
Old Jan 26, 2008 | 06:45 PM
Maxcapacity's Avatar
Default auto or manual ecu how do I find out?
I have a p28 ecu and don't if it's a manual or auto? Is there any thing I can look for to determin which is which? Thanks.
I tried the FAQ thing and could not find this answer...
Old Jan 26, 2008 | 10:20 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: auto or manual ecu how do I find out? (T- rex)
the way to tell is to look at the last 2 characters printed on the tag of the ecu. For an example, i have a ecu that says PM6-L09. you want to look at the L09 portion. If the last 2 digits of that set of characters is 50 or greater, than the ecu is automatic. I believe an automatic pm6 will say something like PM6-A52. It is the same for the OBD1 p28 for sure. obd2 i believe also follows that standard, but i am not 100% sure on that. the first letter of the last 3 values doesnt have anything to do with it, as far as i know. good luck..
Modified by sanimalp at 12:15 AM 1/27/2008
Old Feb 1, 2008 | 07:08 PM
slow93Ls's Avatar
Default Re: auto or manual ecu how do I find out? (sanimalp)
So my pm6-A160 is a auto ecu?
Old Feb 2, 2008 | 02:52 AM
mr.speaker's Avatar
go to http://zdyne.com and look in the tech section.
Old Feb 3, 2008 | 09:31 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: auto or manual ecu how do I find out? (mr.speaker)
A16 i think is a manual.. only the 2 characters after the A matter. sinec those 2 characters are less than 50, its a manual.
JokerX-1.6T
Feb 12, 2007 07:24 PM
cjwarren4dcivic
Feb 1, 2006 11:17 PM
lv6l
10
Dec 10, 2005 10:09 PM
