rear disc brake swap quest. for my '89
I've got the complete swap from a '90 DA going on my '89 rex and was wanting to know - what e-brake cables do I need. Do I use the Integra's or my CRX one's?
Thanks
Thanks
1. search button.. or faq at the top of the page. tells you everything you need to know. but anyway. use the teggy cables. crx ones wont work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oreopeete »</TD></TR><TR><TD CLASS="quote"> use the teggy cables. crx ones wont work</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller »</TD></TR><TR><TD CLASS="quote">integra cables</TD></TR></TABLE>
<FONT SIZE="3">YOU ARE BOTH WRONG.</FONT>
T-rex you want to get 90-91 CRX Si cables they are the correct length and fit properly. If you use Integra ones there will be slack in the cable and will not properly actuate the ebrake.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">
T-rex you want to get 90-91 CRX Si cables they are the correct length and fit properly. If you use Integra ones there will be slack in the cable and will not properly actuate the ebrake. </TD></TR></TABLE>
x2
teggie cables are to long cause the teg chassis is longer then the crx. i just did my swap on a 90 hf crx and the si cables fit perfect!
Modified by zccr-xsi at 6:50 PM 1/27/2008
x2
T-rex you want to get 90-91 CRX Si cables they are the correct length and fit properly. If you use Integra ones there will be slack in the cable and will not properly actuate the ebrake. </TD></TR></TABLE> Does it hurt to be right all the time?
90-91 crx si cables are correct for what you are doing
damn... i could have swore i read it was hatch and crx same.... i am worthless... lol. maybe he should have searched in the first place... lol, then i couldnt have gave the wrong info
hatchblack
26
Jul 17, 2004 07:39 PM
jasonb
Mar 7, 2003 05:31 PM
