Installing D16z6/y8 into CRX, need input
Old Jan 26, 2008 | 04:21 PM
bobash69x2's Avatar
Default Installing D16z6/y8 into CRX, need input
Ok, so I found a D16z6/y8 block/head missing IM and dizzy. Question is, what do I really need to do and what parts do I need to get this swap successful? This will be my first swap so I am very nervous and un-informed. I figured its almost like a mini me, so I have learned the wiring for MPFI and OBD1 and Vtec, but aside from that I havent a clue on what I need and what to do. Here are some pics of said engine to be purchased Wednesday. Also, is $200 a decent price on this? He said milage on bottom end is 120xxx and head is unknown. Thanks in advance
Old Jan 26, 2008 | 04:29 PM
ef_zc's Avatar
Default Re: Installing D16z6/y8 into CRX, need input (bobash69x2)
i did the same swap before my zc and it was my first i did a swap. wasn't that bad the thing that got me pissed off was the dpfi to mpfi that was a bitch but i wired the v tec up to a switch and stayed with my obd0 worked pretty good but the zc has a lot more power then that engine did and nice valve cover i had the same one.But over all the swap wasn't that hard
Old Jan 26, 2008 | 04:40 PM
CRX Toad's Avatar
https://honda-tech.com/zerothread/1508680
Also if you think $200 is a good deal then get it if you don't then don't.
https://honda-tech.com/zerothread/2086185 Please review #4.
Thanks
Old Jan 27, 2008 | 07:42 PM
whiteknightef's Avatar
do it right and convert to 0bd1 or 2 and dont wire a vtec switch PLEASE! get the Arp head stud kit and tell them what your doing. They have a kit especially for this. Get a new honda head gasket and change the water pump while you have it out.
screamin_demon
Aug 7, 2013 08:45 AM
honda305
11
Jan 12, 2007 08:20 PM
Red_ED8
Oct 10, 2005 10:58 AM
