NSX Front Brake Swap in del sol si
GDD's Dr. Phil?
I have searched near and far for a comprehensive part list, and some kind of step by step for this swap with no luck... Please Help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneludesol »</TD></TR><TR><TD CLASS="quote">I have searched near and far for a comprehensive part list, and some kind of step by step for this swap with no luck... Please Help! </TD></TR></TABLE>
GL i searched an only found minimal info as well.. I also found the Euro R Accord front brake setup is bigger than this one, an works out just the same using same brackets and w/e... Its like an 11.5" rotor or something...
GDD's Dr. Phil?
ooh nice, will those fit in 16" wheels? I was going to just go with the powerslot setup, but they are 12" rotors and I am NOT rocking 17's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneludesol »</TD></TR><TR><TD CLASS="quote">thanks
yeah brakeexperts pretty smart dude wit da brizakes... but yeah i think 16's will fit with those 11.5's... if u do the powerslots an wanna trade wheels for my 17's holla...
GDD's Dr. Phil?
Its not that I want to lock up the wheels, but larger diameter rotors disburse heat more efficiently, and I boiled some brake fluid, so im upgrading everything from fluid, lines, and rotors.
https://honda-tech.com/zerothread?id=1171175
https://honda-tech.com/zerothread?id=1484555
on your del sol, unless you've swapped out your knuckles, chances are that you have DX knuckles, which uses 9.5" rotors in the front.
integra type r calipers, stamped 17CL15VN uses a bracket stamped 23T (which can be found in junkyards off integra type-r, accord, prelude, legend, vigor, cl, tl, rl, cr-v, etc), the legend gs 2-pot uses a 25T bracket and 91-96 nsx caliper, a 28T bracket. the calipers & brackets can be swapped back and forth and share the same size pads.
once you obtain the calipers, the brackets must be sent to a machine shop & milled 2-3mm or 1/8" (where the bracket mates with the knuckle). the milled brackets can be used with the 17CL15VN itr, legend gs 2-piston & nsx calipers.
for rotors, use 10.3" rotor from any 90-01 integra. the brake pads also must be filed down (or grinded) slightly to clear the hat of the rotor. [if you plan on swapping to 94-00 integra knuckles w/ nsx calipers & machined brackets, you'll need 11" prelude vtec rotors, which must be re-drilled 4X100]
* on your del sol, upgrade your m/c from a 90-91 civic ex 4-door. since the nsx caliper uses a bigger piston, you'll need to swap out to a bigger master brake cylinder to push more fluid.
https://honda-tech.com/zerothread?id=364783
pm BrakeExpert, he mills brackets and specializes in oem honda brake upgrades
I forget
Jan 6, 2004 02:33 AM
