Possible reasons for steering wheel vibration?
I've noticed the steering wheel vibrates when the car reach to 120km/h (75mph) and the vibration stops when it reach around 140km/h (87.5mph). What could be the possible reason?
I've been told that it might be my tires are off balance. I will bring the car in the shop soon but just want to know what to expect.
btw, my stock tires has 25K km (15K miles) , been on the track 2 times and the left side of each tires are bladed (pretty much) since there are lots of right hand turns on the track that I ran on.
TIA,
CS
TIA,
CS
i think he lost a weight
time to do re-balancing I guess.
btw, why would it only vibrates at 120km/h but not at a higher speed?
thanks,
CS
[Modified by CS, 3:20 PM 7/2/2002]
Could be a broken radial belt, that is what honda found on my new potenza's
I guess that teaches me for having walmart mount my tires
walmart =
tire mounting
walmart =
fried chicken
Eric
walmart =
tire mountingwalmart =
fried chicken
Eric
try to put your rear wheels on the front, fronts in the rear, and see if the car still vibrates. If it does, then it's your wheels (balancing, tires, or wheels). If not, then it's somehting in your suspension.
you mean I lost one of those metal piece on the wheel?
thanks,
CS
thanks,
CS
btw, if you are socal, i can balance it for you free
yeh, you probably did lose one or it moved out of it's original position some how..
[Modified by TypeR 599, 6:35 PM 7/2/2002]
it could be you have dirt or somthing stuck on the inside of the wheel throwing your wheel(s) off balance
just and idea
or what everyone else said
just and idea
if you have those sticky weights, you probably lost 1 or 2. They just fly off over time. look for like some sponge/glue **** on the inside of your rim, if U run sticky weights. That could be a sign of a sticky weight that have flown off.
Toda Party
Oct 27, 2002 07:26 AM
Seann
Jul 29, 2001 02:22 PM
