98 Spec JDM Gauge Cluster and CF console
Old Jan 26, 2008 | 10:26 AM
SupraSaiyan's Avatar
Default 98 Spec JDM Gauge Cluster and CF console
Hey guys,
I was looking for the faux carbon fibre console that I believe are on all 00+ USDM ITRs and came across the JDM console which appears to be the same. Will the JDM centre console, cupholder, side vent fit onto a USDM ITR?
The person also has a 98 spec JDM gauge cluster. He's offering the combo for a smokin price but will the cluster plug n play on my '01 ITR? Both are in kms so thats perfectly fine. I'm talking about the plugs and motherboard and if any modding will be required.
Thanks to all!!!!
Old Jan 26, 2008 | 10:32 AM
eg6ajk's Avatar
Default Re: 98 Spec JDM Gauge Cluster and CF console (SupraSaiyan)
as longest its 98+ spec the cluster is simply a plug and play.
JDM console is shaped the wrong way. Cup holder will work.
rhdc2itr's Avatar
center console and side vent wont fit. The only thing that should work is the cup holder and climate control of a jdm car. The cluster should work.
Old Jan 26, 2008 | 11:34 AM
nautica_t's Avatar
wow these threads always come up like once every two weeks.
Old Jan 26, 2008 | 11:52 AM
Default Re: (nautica_t)
I swear I tried searching before posting! All threads related are ppl swapping speedos into the jdm cluster and srs plug.
So assuming the climate control and cup holder will work, the ashtray and lighter should fit, right? I am sure the window switches doesn't fit, but can anyone confirm?
Thanks!!
Old Jan 26, 2008 | 12:23 PM
nautica_t's Avatar
if you're refering to the flux window switch cover than the passenger side will fit fine, however the driver's side will have to be modded to work properly as the opening for the auto-down is not in the right slot anymore, due to lhd vs rhd, so there you go.
sportinjected
Aug 17, 2008 04:43 PM
LilChuck
Apr 21, 2005 01:43 PM
EGJdmJreams
Nov 12, 2004 06:42 PM
shoei
Sep 23, 2004 08:17 PM
