Passenger Door Handle Broken?
Old Jan 26, 2008 | 10:16 AM
Xxtayce's Avatar
Default Passenger Door Handle Broken?
'93 Del Sol SI.
When it first started happening, the door would open from the outside, but not the inside. After a while, the door now will not open at all. (Manual lock, not automatic.)
I've been told to take off the door panel on the inside and I can fix it, but it seems like the bolts are behind the dash, and if the door won't open, it's basically impossible to take the door panel off.
On the driver's side, the little light next to the door handle is missing, so I'm assuming this happened once previously and that was the fix for it. Could I get to it that way? And if so, what do I do then?
As cool as it is to make my passengers revive an episode of Dukes of Hazard every time they ride with me, I'm getting tired of clumsy people getting mud on my passenger seat.
Old Jan 26, 2008 | 11:59 AM
silentbeatz's Avatar
it might be the plastic clip behind the handle. check to see if the hook is still connected to the clip.
Old Jan 26, 2008 | 12:41 PM
SIC-CIVIC's Avatar
like he said^^^ try to take the inside handle off and see if you can pull the rod with your fingers or a pair of pliers to get it open then go from there.
1yesfan
Apr 30, 2015 08:31 AM
marcelosm
10
Jul 28, 2014 05:45 PM
bkopel805
Feb 26, 2011 11:52 AM
Bob Dole!
Nov 25, 2009 01:12 PM
Frost7177
Oct 27, 2008 01:31 PM
