Clunking sound when stoping at lower speeds?
Old Jan 26, 2008 | 09:58 AM
supra360's Avatar
Default Delete
Delete
Old Jan 26, 2008 | 10:14 AM
crxgator's Avatar
Default Re: Clunking sound when stoping at lower speeds? (supra360)
could be worn lca bushings or maybe your passenger motor mount...
Old Jan 26, 2008 | 12:17 PM
Tiger_Si's Avatar
if it is lowered, and you didnt fix the camber, probably the wheel bearing.
Old Jan 26, 2008 | 01:08 PM
SuckMyDOHC's Avatar
only durring braking or when you accelerate from a stop as well?
Old Jan 26, 2008 | 11:47 PM
EM1 Loi's Avatar
Default Re: (SuckMyDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC &raquo;</TD></TR><TR><TD CLASS="quote">only durring braking or when you accelerate from a stop as well?</TD></TR></TABLE>
i got this problem as well...it's not the sway bar, it's not the motor mounts, not the axles, only thing i can think of is my lca bushings the ones that are pressed into the lca not the big one.
Old Jan 27, 2008 | 08:31 AM
Jamie98RS's Avatar
Default Re: (EM1 Loi)
I've had a wheel bearing make that kinda of noise before.
Old Jan 28, 2008 | 11:11 AM
supra360's Avatar
Only during breaking at low speeds... i replace my wheel bearing last year... the car is stock no mods done to it...
EM1 Loi
Jul 31, 2008 09:15 AM
DFW
Suspension & Brakes
Sep 16, 2006 11:32 AM
The Weather Man
Feb 6, 2006 06:25 PM
SilverDc2
Jan 5, 2006 10:25 AM
fe519
May 19, 2003 07:29 PM
