Which Oil pump
Will i be good with a Jdm B16A Oil pump on my b16A for my boosted setup... im a t3/t67 17-22 Psi 8.5.1 comp eagle rods ??? or should i get a Type R oil pump n do all Type rs bolt to my moter ?? no matter year just as long as its a B series?? thanks
what year is your block also i dont believe B16 oil pumps are the same as B18 oil pumps.
also why do you need a type-r oil pump its the exact same as a GSR one dont like names fool you look at the OEM part number
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sorrule »</TD></TR><TR><TD CLASS="quote">Don't quote me on the year but I believe all the Bseries oil pumps 98+ non vtec or vtec are the exact same.</TD></TR></TABLE>
its 96+ Bseries are all the same but i cant remember if B16s fit on B18s or not i think it was something about the height difference. oh search in the integra FAQ section there a bunch of information in there if you look
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 »</TD></TR><TR><TD CLASS="quote">its 96+ Bseries are all the same but i cant remember if B16s fit on B18s or not i think it was something about the height difference. oh search in the integra FAQ section there a bunch of information in there if you look </TD></TR></TABLE>
think about what you just said. if all 96+ b series oil pumps are the same why wouldnt a b16 pump fit on a b18?
i have a motor stamped 95 but has all obd2 things on it, what oil pump do you think it has?
theory, obd0 has that little bird looking stamp on the back
obd1 has that stamp on the front side but its small
obd2 has it big on the front
what do you think? or is there a way to distinguish vtec and non vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">
think about what you just said. if all 96+ b series oil pumps are the same why wouldnt a b16 pump fit on a b18?</TD></TR></TABLE>
think about this why cant you use GSR, LS, or ITR rods in a B16 block ?
HondaCivicSiR1
Apr 2, 2008 06:07 PM
civcexcoupeblack
Sep 14, 2003 05:38 PM
