need help
Old Jan 26, 2008 | 08:55 AM
David27's Avatar
Default need help
hey i just got done putting a b16 into my friends 91 ef i did the dpfi to mpfi everything seems to run perfect but its like it has a rev limiter at 3500. i tought that it could be the tps sensor but i had another throttle body that i switch out and the same thing happened, i was told that you have to switch two of the wires on the map sensor but cant find anything about it on here, so if anyone could help or has had this problem let me know thanks
Old Jan 26, 2008 | 09:27 AM
ludesrv's Avatar
Default Re: need help (David27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by David27 &raquo;</TD></TR><TR><TD CLASS="quote">hey i just got done putting a b16 into my friends 91 ef i did the dpfi to mpfi everything seems to run perfect but its like it has a rev limiter at 3500. i tought that it could be the tps sensor but i had another throttle body that i switch out and the same thing happened, i was told that you have to switch two of the wires on the map sensor but cant find anything about it on here, so if anyone could help or has had this problem let me know thanks</TD></TR></TABLE>
Everything isn't perfect if it's rev cut is 3500 rpm. That's limp mode. What CEL do you have?
Change the dizzy with a known working one. I'm suspecting your wiring.
Old Jan 27, 2008 | 08:41 PM
David27's Avatar
i fixed it one of the pins wasnt pushed in all the way b10 i think crank positions sensor but all good now thanks
0ldsk00lef
Aug 22, 2007 08:55 PM
DirtRider
Jan 1, 2006 12:23 PM
kechup2eg6
Aug 10, 2005 07:47 PM
jokr78
Jan 4, 2005 10:45 AM
shadowstylz
Aug 19, 2003 06:31 PM
