valve springs, and valves
No as in - they won't fit - S2000 valves are bigger in diameter and longer - D16vtec valves are Longer on the stem. So No and No. Figure out which head you have, Get valves for it or since you probably going to have your head off(or do now) Mini-me it(Put a vtec head on your non-vtec block) and gain the extra power from the Vtec. Or you could just stay with your head you have now - Man you have some options....
HENRY
HENRY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by festivagt »</TD></TR><TR><TD CLASS="quote">No as in - they won't fit - S2000 valves are bigger in diameter and longer - D16vtec valves are Longer on the stem. So No and No. Figure out which head you have, Get valves for it or since you probably going to have your head off(or do now) Mini-me it(Put a vtec head on your non-vtec block) and gain the extra power from the Vtec. Or you could just stay with your head you have now - Man you have some options....
HENRY</TD></TR></TABLE>
hmm.... damn that sucks. was hoping the valves would fit cause heard some guy with an old 87 si ran s2000 valves in his engine with out too many modifications and was hoping since it fit in that engine it would fit in my d16. and with the valves, my brothers got a d16 vtec engine lying around at his shop and was hoping that the valves would fit. was hoping to keep the head i have now and run that valve and spring combo(was hoping on cheating in autox and keep the car in HS) but i guess i'll just have to just rebuild it then. thanks anyways.
SirRevvs
Oct 14, 2010 10:32 AM
