JDM EF b16a o2 question
Old Jan 26, 2008 | 06:36 AM
SiR_Injected's Avatar
Default JDM EF b16a o2 question
since there is o2's right next to eachother can i mod this in any way is it necessary to use 2 sensors ? i see how the 18 teg just use's one ... if ya got any tips let me know
Old Jan 26, 2008 | 07:01 AM
jamison1486's Avatar
Default Re: JDM EF b16a o2 question (SiR_Injected)
it probably helps to use the two o2 sensors but ive got the 2nd gen. b16 in my crx and i only use a wideband. seems to work fine.
Old Jan 26, 2008 | 11:33 AM
floridarex's Avatar
hook them up the right way, get the right ecu and the sub harness. Trust me it will make your life so much easier. I bought a 4-2-1 header and had the 02 bungs welded in the right places.
Old Jan 26, 2008 | 03:38 PM
HondaPartsHero's Avatar
Technical Hero
hook both of them up
Old Jan 26, 2008 | 04:06 PM
mullet eater's Avatar
Default Re: JDM EF b16a o2 question (HondaPartsHero)
Is that the only way the o2s will work with the car still running good and no engine light? Does anybody else have pictures of their setups I would love to see them?
Old Jan 26, 2008 | 06:58 PM
Zaakro's Avatar
Default Re: JDM EF b16a o2 question (mullet eater)
that is the only way unless you are running OBD1 than you only use 1 O2 sensor and its at the end of the Exhaust manifold.
if you don't do it right your car will run like crap
Old Jan 27, 2008 | 02:34 AM
Default Re: JDM EF b16a o2 question (Zaakro)
i didnt think think to mention it in my first post, but yeah, my egine is obd-1 w/ a chipped p28 . if you've got obd-1 i think you'll be ok
Old Jan 27, 2008 | 05:39 PM
lsvtec hf's Avatar
Default Re: JDM EF b16a o2 question (jamison1486)
Think this would (both o2's hooked up) cause a untuned, high compression lsvtec to run lean? I was told to only run one o2 sensor until I do the OBD-1 conversion and a good tune. Both of them hooked up would cause my set up to run lean?... Im running the PWO ecu.
Old Jan 29, 2008 | 07:40 PM
lsvtec hf's Avatar
Default Re: JDM EF b16a o2 question (lsvtec hf)
anyone?
justin1785
Jul 9, 2010 02:55 PM
1320king
74
Feb 13, 2007 09:06 PM
aaronhume
Aug 10, 2006 08:54 AM
JOGADOGGZ
Sep 20, 2005 09:38 AM
kagegod
May 10, 2004 03:01 PM
