code
code# 20
Accord Civic CRV CRX Del Sol Odyssey Prelude
90-98 88-98 97-98 88-91 93-97 95-98 92-98 ==Electrical Load Detector==
the way i fixed that was by changing my fues box under the hood. it worked for me after that. i had a crx...
i also have a problem with the wiring, will the ELD make it so my wiring go crazy.
crazy like when i press the brake the gauges go crazy and it smokes like wires are burning? and when i tap the gas pedal i hear clicking and my engine starts to cut off. i turn on my lights on and same problem with gauges. even when i try to roll up the window it does the same thing.
need help, no experiance in the wiring field
that sucks.
but check all your gounds. and look where the wires a burning(smoking)
check your o2 sensor and see if those wires are melted together.
all i can say if find the wires that are burning and fix them...
