help stock type r.bin for turboedit
Old Jan 25, 2008 | 08:50 PM
mario_pic's Avatar
Default help stock type r.bin for turboedit
hi there i need some help locateing a .bin for a stock integra type r im looking to go turbo so what i got planed is to run a reprogramed obd1 ecu to run a type r motor with turbo can eney one help me out please
Old Jan 26, 2008 | 06:22 AM
meots98itr's Avatar
Default Re: help stock type r.bin for turboedit (mario_pic)
Old Jan 26, 2008 | 07:38 AM
Doostur's Avatar
Nani?
Old Jan 26, 2008 | 10:06 AM
eg6ajk's Avatar
http://www.pgmfi.org
or
http://www.tunewithcrome.com/
Old Jun 5, 2008 | 02:16 PM
mouab18c1's Avatar
Default Re: help stock type r.bin for turboedit (eg6ajk)
bump this...i need a type r bin to burn onto my p28
Old Jun 5, 2008 | 09:27 PM
downest's Avatar
Default Re: help stock type r.bin for turboedit (mouab18c1)
TurboEdit is OBD0, but you're talking about OBD1. What do you really need?
If you are going OBD1 that's easy, there are plenty of bin repositories out there and plenty of base maps for ITRs. If you can't find one just start from scratch on Crome. If you need to convert it to OBD0 for turboedit/BRE it's a little more complicated since the scalars are a lot different, what I usually do is plug in a spread sheet that averages the rows (there are more RPM scalars with OBD1) to make more rows that fit OBD0, and condenses the load columns to fit the OBD1 tables (using Crome). You'll still have to tune it.
If you're staying OBD0, we have a couple of ZDyne units at the shop, IIRC one has a map from a turbo B18C5 on it.
Old Jun 5, 2008 | 09:58 PM
mouab18c1's Avatar
Default Re: help stock type r.bin for turboedit (downest)
nvm i got what i needed...but thanks anyways
ac26
Apr 2, 2010 02:41 PM
zammitjon
Feb 7, 2009 08:36 AM
SlepT ej6
12
Jun 22, 2005 11:11 PM
AW
Aug 29, 2002 07:33 AM
b16aeg6
Mar 14, 2002 11:39 PM
