Suspension & Brakes Theory, alignment, spring rates....
Koni + GC + GC Top hat, which height should i use?
Old Jan 25, 2008 | 05:11 PM
n1_egsex's Avatar
* B A N N E D *
Default Koni + GC + GC Top hat, which height should i use?
i just got my set of koni yellows + gc's
when i assembled them, the rear clip came on the middle ring, i assembled everything and it seemed like i had to spin the ring all the way up just to preload the suspension, so i moved the clip up one level, and it seemed better
question is, does it affect anything by which ring i use? here's a pic of what i'm talking about
it came factory on the #2, but i moved it up to #1
Old Jan 26, 2008 | 07:21 AM
2ToneEM1's Avatar
I installed mine on the bottom ring
Old Jan 26, 2008 | 12:35 PM
Targa250R's Avatar
be professional
Default Re: Koni + GC + GC Top hat, which height should i use? (n1_egsex)
It doesn't matter much which groove you put the circlip in, since they are adjustable coilovers. All it will affect is the position of the perch on the sleeve.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex &raquo;</TD></TR><TR><TD CLASS="quote">it seemed like i had to spin the ring all the way up just to preload the suspension</TD></TR></TABLE>
You don't preload it at all. The spring perch sets the ride height.
Old Jan 26, 2008 | 02:10 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: Koni + GC + GC Top hat, which height should i use? (Targa250R)
oh ok, so the GC's should be loose on the shocks when the car is jacked up, and the perch only affect ride height, got it
Old Jan 29, 2008 | 06:04 AM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex &raquo;</TD></TR><TR><TD CLASS="quote">The GC's should be loose on the shocks when the car is jacked up, and the perch only affect ride height.</TD></TR></TABLE>
My Koni Sport circlips are set at the top groove in the front and middle groove in the rear.
Modified by gabebauman at 9:17 AM 1/29/2008
bmoua
Suspension & Brakes
Jan 30, 2008 03:14 PM
n1_egsex
Jan 28, 2008 10:33 AM
importdude2000
Suspension & Brakes
Jun 17, 2007 07:28 AM
BDogggUT34
Suspension & Brakes
Mar 31, 2006 08:34 AM
latin_racer
19
Jun 23, 2004 12:01 PM
