converting to rear disc
They probably are the same...
Our '00 Si had the same size as our 97 H/B.
But I don't understand why you would want to change the one that is on the DX anyway?
Kiwi
Kiwi
Sounds like he's converting the rear drums to discs. I have read (and I'm guessing Shane has as well) that if you don't switch to a 40/40 prop valve, the F/R brake bias will be screwed up.
Im just gonna try the dx prop valve and see how it all works out. I ended up buying power slot rotors and EBC yellows F/R. I also grabbed some stainless lines. I will let you guys know Tuesday after we install. Oh yeah i got new rear KYB AGX's to replace the 6 year old ones
ROTEN EF8
May 8, 2007 06:35 PM
