clunking noise from steering rack?
Old Jan 25, 2008 | 12:44 PM
ITR.#1446's Avatar
Default clunking noise from steering rack?
i have this clunking noise when i shaking the wheel back forth coming from the steering rack when the car is off. I checked the tie rod end ball joints and they were ok , then i checked my wheel bearing drivers side was very bad replaced that and still have the noise. My sector shaft going into the steering box is within spec so i assume its the tie rod. I have a couple pics of where i think the noise is coming from and what do i order ? Does the tie rod come with the ball coupler thingy or is that a separate part also?
should i also order a new boot while i am at it? or do they boot band and tube clamp?
Modified by ITR.#1446 at 2:28 PM 1/25/2008
Old Jan 25, 2008 | 02:22 PM
crxgator's Avatar
Default Re: clunking noise from steering rack? (ITR.#1446)
when i changed my tie rods on my crx the inner tie rod was that one piece, with the ball coupler...
order a new boot, band and hardware like the nut and washer as well...it's not that expensive for all of it...
Old Jan 25, 2008 | 03:03 PM
walker111's Avatar
Default Re: clunking noise from steering rack? (crxgator)
Its not that expensive to replace the whole thing, I'd do it if thats what creating the noise...
<who doesnt like to shortcut a ball joint issue. Also I have never replaced a boot.....no definitive way to tell that dirt/sand didnt get in the grease.
Old Jan 25, 2008 | 03:14 PM
ITR.#1446's Avatar
Default Re: clunking noise from steering rack? (walker111)
yeah im am pretty positive thats where the noise is coming from i have engine out right now and when i sit there and look thats where the noise is coming from i have not taken off the boot yet to see if it looks worn.
Old Jan 25, 2008 | 03:19 PM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">yeah im am pretty positive thats where the noise is coming from i have engine out right now and when i sit there and look thats where the noise is coming from i have not taken off the boot yet to see if it looks worn.</TD></TR></TABLE>
imo your not gonna be able to tell whats shot or not..... if that is indeed it, spend the 13 53540-S04-013 END, R. TIE ROD 1 2000 INTEGRA 40.87 32.70 and replace it.
Bob W.
Honda Civic (2006 - 2015)
Oct 21, 2017 06:19 PM
JDMPR
Mar 25, 2013 08:40 PM
Rudy84
Sep 15, 2010 11:21 AM
petwhookie
Suspension & Brakes
Jan 12, 2010 03:22 PM
Matgallis
Feb 20, 2004 07:21 AM
