Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Trouble with Friends Greddy Ti-C Catback Silencer...
Old Jan 25, 2008 | 11:24 AM
Blackline47's Avatar
Default Trouble with Friends Greddy Ti-C Catback Silencer...
Ok my friend recently got a Ti-C on his 07 Si and he did'nt install it he pay'ed a shop to do it. and They did'nt take out the silencer. To take it out it was easy you just needed to unbolt the 3 nuts and washers and screws. Then just tug on it a little. and that suckers out....
Not my friends.... We unbolted the nuts. took out the tip of the exhaust. should slide right out? right? NO! It wont even budge we did the close hanger trick, the chisel hammer and just grabbing and pulling. It will not come out.
I think its because its winter time now. Its going to expand when its real cold and shrink a little when its warm. And i guess it expanded to much and it wont come out Thats what i think is happening. Any Trick on doing this? mine slide right out!!
Anyone suggest anything? He's coming over in the day time so i will see what i can do for him.
Poor guy
haha- and have a good weekend guys
Old Jan 25, 2008 | 11:31 AM
pd0019's Avatar
Default Re: Trouble with Friends Greddy Ti-C Catback Silencer... (Blackline47)
you're best bet is to warm up his car an then see if it will come off with the help of some wd40 or pb blaster (dunno if that will work)?. its not b/c of the cold weather as much as it is from your friend just running his car normally. turn your car on and the exhaust gets hot, heating up the muffler. once the car is turned off, your muffler cools down and the metal expands.
if it has been on for more than 2-3 weeks im pretty sure it wont come off. i had this happen on my old car and i think the only way to get it off would be with a plasma cutter.
good luck.
Old Jan 25, 2008 | 11:51 AM
Default Re: Trouble with Friends Greddy Ti-C Catback Silencer... (pd0019)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pd0019 &raquo;</TD></TR><TR><TD CLASS="quote">you're best bet is to warm up his car an then see if it will come off with the help of some wd40 or pb blaster (dunno if that will work)?. its not b/c of the cold weather as much as it is from your friend just running his car normally. turn your car on and the exhaust gets hot, heating up the muffler. once the car is turned off, your muffler cools down and the metal expands.
good luck.</TD></TR></TABLE>
LOL your seriously telling me to try to take it out when its running? you make me laugh my friend. WD-40 might work ill give it a try when hes here tomorrow.
Old Jan 25, 2008 | 12:24 PM
spanishfly's Avatar
wd-40
Old Jan 25, 2008 | 12:31 PM
TypeRBoy's Avatar
Default Re: Trouble with Friends Greddy Ti-C Catback Silencer... (spanishfly)
You have got your chemical properties backwards my friend. Only water expands when it cools. All other materials, including metal, shrink when they are cold and expand when hot. Example: to make certain wheels, they torch the loop of the rim and super chill the center portion before assembling them. This shrinks the inner part and expands the outer part. Once they are put together and come down to room temp., they cannot be taken apart. If you heat the whole exhaust, both parts will expand and will not help you. Try some penetrating spray.
Old Jan 25, 2008 | 01:18 PM
pd0019's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackline47 &raquo;</TD></TR><TR><TD CLASS="quote">
LOL your seriously telling me to try to take it out when its running? you make me laugh my friend. WD-40 might work ill give it a try when hes here tomorrow. </TD></TR></TABLE>
lol....my bad...i meant warm it up, shut off your engine and then go for it
my bad for not clarifying. never meant to tell you to kill yourself by inhaling exhaust fumes or did i?
Old Jan 25, 2008 | 02:08 PM
my bad for not clarifying. never meant to tell you to kill yourself by inhaling exhaust fumes or did i?</TD></TR></TABLE>
Old Jan 25, 2008 | 06:10 PM
ill keep you guys updated
Old Jan 25, 2008 | 06:44 PM
Tokyosmash!'s Avatar
Tickle-shits
Community Builder
Community Influencer
Why didnt he just take the silencer out first? Silencer
Old Jan 25, 2008 | 08:37 PM
Default Re: Trouble with Friends Greddy Ti-C Catback Silencer... (Tokyosmash!)
lol dont ask me. I dont think he knew that there was one in it when he had the shop installed it.
they said it was "muffer tip attender" i should of just installed it for him. But to late now. Hopefully we can get it out tomorrow!
time to dig out the old WD-40 in the basement.
Old Jan 26, 2008 | 09:15 AM
It did'nt come out we tried everything! That thing is not coming out!
Old Jan 26, 2008 | 09:32 AM
elohel's Avatar
LOL your seriously telling me metal expands when it's cold and shrinks when it's warm?
Old Jan 26, 2008 | 02:07 PM
2008fijibluesi's Avatar
Default Re: Trouble with Friends Greddy Ti-C Catback Silencer... (TypeRBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRBoy &raquo;</TD></TR><TR><TD CLASS="quote">You have got your chemical properties backwards my friend. Only water expands when it cools. All other materials, including metal, shrink when they are cold and expand when hot. Example: to make certain wheels, they torch the loop of the rim and super chill the center portion before assembling them. This shrinks the inner part and expands the outer part. Once they are put together and come down to room temp., they cannot be taken apart. If you heat the whole exhaust, both parts will expand and will not help you. Try some penetrating spray.</TD></TR></TABLE>
x2345363
Old Jan 28, 2008 | 08:45 AM
CivicProject08's Avatar
Default Re: Trouble with Friends Greddy Ti-C Catback Silencer... (2008fijibluesi)
insert crow bar. move crowbar up and down. it will come out. mine was stuck today and just got it out using this method.
Old Jan 28, 2008 | 08:54 AM
Type X's Avatar
Actually as stated above, the only correct way to get it out would be to heat up the exhaust so that it expands.
after that is completed (USING PROPER GLOVES) you can remove it using your OEM honda "hook" jack tool
Regards,
-mike
sloweh3
Nov 4, 2005 11:45 AM
AccordRacing
Oct 9, 2005 10:49 PM
sam385
Sep 19, 2005 08:14 PM
LuderCriS
Aug 28, 2002 05:36 AM
RedRacer
Feb 11, 2002 08:23 PM
