code 14 iacv
Old Jan 25, 2008 | 10:13 AM
slo_b18's Avatar
Default code 14 iacv
my car is throwing a code 14, is there anybody that can help me?
things i have done:checked for vacuum leaks, tps voltage, replaced iacv for a brand new one, ran it straight to the ecu because its not working with the plug. [ all this was done recently]
the car has thrown the code 14 ever since i put a ls in it obd 0, that was 4 years ago, then i put b16 head on it 2 years ago, still code 14 different working iacv and still obd 0. so i've alway had code 14 but my car always ran fine until i converted it to obd 1 a month ago, it idles fine, runs and drives fine. the only problem is that when i give it gas[normal driving] it responds about a second or two later followed by a jerk.
Old Jan 27, 2008 | 12:14 AM
civicstar's Avatar
Default Re: code 14 iacv (slo_b18)
check the voltage to and from the IACV and then try resetting the ECU
Kris's turbo
Mar 24, 2012 02:42 PM
Mach69
Jul 19, 2005 11:47 AM
crxtreme27
Feb 4, 2004 10:19 PM
Bnjmn
Jan 3, 2004 04:50 PM
HondaCutie90
Feb 25, 2002 09:43 AM
