Suspension & Brakes Theory, alignment, spring rates....
5 lug conversion question?
Old Jan 25, 2008 | 10:10 AM
Spec R_GSR's Avatar
Default 5 lug conversion question?
I recently did a 5 lug conversion on my 98 GSR and put on DC5 Type R wheels. Now my first question is this if my stock offset was +45 and with my new wheels i dont know what the hell it is now? The wheels by them self are +60mm what i notice is they do rub a little on the inner wheel well but not much i could live with it my car is tucked to the ground and i like the fact that the wheels are under the car with minimal camber. My Second question is this, if i change my offset from stock to what ever it is now let say 55mm would it totally mess up my handling and should i try to space it out some?
Old Jan 25, 2008 | 02:13 PM
SilverDc2's Avatar
Default Re: 5 lug conversion question? (Spec R_GSR)
OEM ITR wheels shouldn't rub. you probably need an alignment.
Old Jan 25, 2008 | 02:27 PM
Spec R_GSR's Avatar
Default Re: 5 lug conversion question? (SilverDc2)
The rubbing is not my concern i just want to know if having a lesser offset in essence bringing the wheelbase in toward the car would that affect my handling
Old Jan 25, 2008 | 02:33 PM
SilverDc2's Avatar
Not in a negative way,. I had a 5 lug for several years. the hub and rotor seem thicker and pushed out further than a normal integra. Also the offset on the itr is 50+
Old Jan 26, 2008 | 12:11 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R_GSR &raquo;</TD></TR><TR><TD CLASS="quote">The rubbing is not my concern i just want to know if having a lesser offset in essence bringing the wheelbase in toward the car would that affect my handling</TD></TR></TABLE>
It's certainly not as detrimental to "handling" as driving the car "tucked to the ground" and "with minimal camber."
Old Jan 26, 2008 | 12:48 PM
Spec R_GSR's Avatar
Default Re: 5 lug conversion question? (Targa250R)
ok thanks but this is what it looks like
blindguy
14
Sep 7, 2008 02:28 PM
Spec R_GSR
Jan 29, 2008 11:39 AM
teranishi
Oct 7, 2005 01:40 PM
2lude4u
Jan 14, 2005 04:34 PM
SubieDude
May 28, 2002 03:07 AM
