Is it acceptable to shave the sides of CR small end to provide appropriate rod to piston clearance?
Old Jan 25, 2008 | 09:23 AM
jetlude's Avatar
Default Is it acceptable to shave the sides of CR small end to provide appropriate rod to piston clearance?
Its for a H22 using JE pistons and crower rods. When assembled the clearance is less below minimum spec. Is this the correct thing to do?
Old Jan 25, 2008 | 03:40 PM
jetlude's Avatar
anyone?
Old Jan 25, 2008 | 09:21 PM
Steve D's Avatar
Default Re: (jetlude)
You can machine the pin end of the rods for clearance as long as the amount is minimal. You didn't specify how much needed to be removed.
Old Jan 26, 2008 | 05:45 AM
JDogg's Avatar
Default Re: (Steve D)
yeah, take em to the grinder, you will need to use a hone on the pin bushing b/c it will bur up.
thats how i made my first set of mahle pistons fit,
Old Jan 26, 2008 | 02:02 PM
jetlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve D &raquo;</TD></TR><TR><TD CLASS="quote">You can machine the pin end of the rods for clearance as long as the amount is minimal. You didn't specify how much needed to be removed.</TD></TR></TABLE>
have to remove.082 (.041 per side) from each rod. Rod pin end width will now be .855"
Old Jan 27, 2008 | 02:43 PM
Steve D's Avatar
.855" is fine on width. I have a set of titanium Honda Crower rods here measuring .858".
If you have a lathe with enough swing, best way to machine the pin ends would be with the pin end mounted to an expanding mandrel. Second best would be on a Bridgeport mill if you can hold the rod so the pin bore is vertical. Chamfer the bushing and debur the rod when you are finished.
Steve
Old Jan 28, 2008 | 02:22 AM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetlude &raquo;</TD></TR><TR><TD CLASS="quote">
have to remove.082 (.041 per side) from each rod. Rod pin end width will now be .855"</TD></TR></TABLE>
yeah, i had to remove about the same ammount from some eagles to fit the orignal mahle pistons i had..
Old Jan 28, 2008 | 03:42 AM
jetlude's Avatar
Default Re: (JDogg)
Thanks for the info guys
bluedlude
Dec 15, 2007 05:50 PM
Aquafina
10
Jul 16, 2007 12:25 PM
zensoku207
Feb 10, 2004 12:42 PM
CRX Lee
Feb 9, 2004 08:39 AM
