309 rod for welding mild steel?
Old Jan 25, 2008 | 07:10 AM
all_motor_mike's Avatar
Default 309 rod for welding mild steel?
simple question............ would there be any problems with using 309 rod to weld together a sch 40 mild steel turbo manifold or should i use ER70S?
mike
Old Jan 25, 2008 | 08:28 AM
k24em2's Avatar
Default Re: 309 rod for welding mild steel? (all_motor_mike)
Use the right rod.
ER70S-2
Seriously, ER70S-2 is DIRT cheap
Old Jan 25, 2008 | 04:04 PM
Default Re: 309 rod for welding mild steel? (k24em2)
i have some already............. the 309 just looks better after welding. i didnt want any premature failure because i used the incorrect rod thats all. thanks for the reply,
mike
Old Jan 25, 2008 | 04:38 PM
SMSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_motor_mike &raquo;</TD></TR><TR><TD CLASS="quote">i have some already............. the 309 just looks better after welding. i didnt want any premature failure because i used the incorrect rod thats all. thanks for the reply,
mike</TD></TR></TABLE>
I use it alot but I back purge.
Old Jan 25, 2008 | 08:31 PM
bigTom's Avatar
Default Re: 309 rod for welding mild steel? (SMSP)
I use stainless rod on MS all the time for various reasons without ever having a problem.
Old Jan 26, 2008 | 01:35 PM
ManBearPig4silly's Avatar
Default Re: 309 rod for welding mild steel? (bigTom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">
I use it alot but I back purge.</TD></TR></TABLE>
Why would you do that? I mean seriously. You preach so much about doing things right and then you use the wrong filler so it looks prettier and it's easier to weld with? So you charge the customer more so you can use 309 rod on MS and backpurge it? er70s was designed for you know......general use on mild steel plus it's cheaper and doesnt require purging. So again why do you use 309? You really baffle me dude. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigTom &raquo;</TD></TR><TR><TD CLASS="quote">I use stainless rod on MS all the time for various reasons without ever having a problem. </TD></TR></TABLE>
I hope it's not structural at all. Only baby jesus and welding engineers know what alloy concoction the weld area actually is.
But yeah for things that don't really matter or in a major pinch i do it too
Old Jan 26, 2008 | 02:08 PM
ditch_bound's Avatar
If you are going to use a stainless filler on mild steel the only thing you can use is 309. There is nothing wrong with using 309 other then the fact it cost more and it may sugar.
TIGboy
Welding / Fabrication
21
Dec 3, 2011 04:45 PM
55superbeetle
Oct 2, 2007 10:14 PM
.john.
Sep 4, 2007 06:39 AM
dfoxengr
40
Jun 27, 2007 07:36 AM
boostedcivicsir
Jan 29, 2006 11:46 AM
