Engine Swap Checklist?
Old Jan 24, 2008 | 07:50 PM
cmoreno88's Avatar
Default Engine Swap Checklist?
Did anyone ever make such a thing. I want to swap a 94' LS into my 92' EG8. My car is currently automatic. I will be converting to stick. I am looking for a detailed list for everything I am going to need from the integra. I live in California and I plan on reffing my vehicle. Here's what I got so far:
Engine
Transmission/Flywheel/Clutch
ECU
Dizzy
Harness
Stock Intake Manifold w/ Injectors
Stock Exhaust Manifold
Stock Air Box/Intake Arm
Mounts...Not sure if I have all the ones I need though
Axles
Shift Linkage
Master/Slave Cylinder
Interior Pieces
Pedal Set
Upgraded Suspension
If anyone can fill me in on what else I need or send me a link it greatly be appreciated. Thank you.
Old Jan 24, 2008 | 08:22 PM
matty413's Avatar
Default Re: Engine Swap Checklist? (cmoreno88)
Dont know why you would need mater or slave cylinder but I guess I'm confused about what exactly your trying to do because you wrote down interior pieces but from what man???? If you wanna put in an LS you need Bseries mounts also so any of them with work for your EG
Old Jan 24, 2008 | 08:59 PM
bpkmrtoes's Avatar
Default Re: Engine Swap Checklist? (matty413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matty413 &raquo;</TD></TR><TR><TD CLASS="quote">Dont know why you would need mater or slave cylinder but I guess I'm confused about what exactly your trying to do because you wrote down interior pieces but from what man???? If you wanna put in an LS you need Bseries mounts also so any of them with work for your EG</TD></TR></TABLE>
hes converting from auto. thats why he needs those. he also needs the auto to manual conversion tranny mount. (not sure if he needs one for a hybrid swap or if there is such thing...)
OP would probably need:
a T/b if the I/M doesn't have one.
a b series throttle cable
new I/M gaskets and T/B gaskets if they are apart
a new bitch-pin
B-series Starter and Alternator
Some grease for axles and shafts.
Some Cotterpins if he messes his up.
4 qts of Motor oil.
3 qts of Tranny Fluid
1-2 jugs of coolant.
big bottle of dot3/4 Brake/clutch fluid.
maybe a new thermostat if his is bad.
should do a preventative maintenace and replace timing belt, water pump, and obvious tune up items like new cap, rotor, spark plugs, spark plug wires, air filter, fuel filter.
that should be it.... other than various nuts and bolts he should be missing like two 12's to hold the shifter up, the 12 with the big washer to hold that bushing in on the tranny and shiftlinkage... etc...
Old Jan 24, 2008 | 11:15 PM
cmoreno88's Avatar
thank you. this is why i came to Honda Tech!
Old Jan 25, 2008 | 09:21 AM
austinkli's Avatar
Default Re: (cmoreno88)
http://www.jdmtigerjapanese.co...1fe22
got what you need right there.
Old Jan 25, 2008 | 10:36 AM
w0nd3r's Avatar
-the clutch bleeding swap
-any mount from integra or eg6 or ej1 will work, but you need the ls or gsr L bracket(it's the back motor mount bracket)recommend after market or new mounts
-obd1 everything
good luck on your project
Old Jan 25, 2008 | 11:37 PM
cmoreno88's Avatar
thanks for the replies guys.
manny516
Feb 26, 2012 05:23 PM
xtimmmyx
Jul 3, 2006 02:31 PM
HalvieCuw
18
Jan 28, 2005 07:16 AM
Lewis7789
15
May 29, 2004 02:25 PM
deviant1
Jan 27, 2003 06:26 AM
