Camber Kit any good?
These are VISION Motorworks Adjustable front And Rear Camber Correction Kit I was just wondering if they are any good? or if anybody has tried them?
The rear upper arms are a fairly typical design but I have zero experience with this brand. The front upper arms...I don't know how much the Vision arms cost, but you can certain purchase upper front control armswith bushings from either Skunk2 or Omni - I've used both. you need to factor in the cost of bushings and the labor to have these pressed. Ofg course, then you have the option to chose the bushing material.
i don't like the design of the front upper control arms, they look like they'll bust up your front shock towers, the 4 bolts hitting against the shock tower that is. designwise you need a thinner looking piece over where the ball joint is for clearance.
i would say get an adjustable front ball joint instead (for shock tower clearance issues).
the rears look fine. or you can just get stainless steel washers and get an aligment shop to adjust it by adding or removing washers.
hope this helps.
hope this helps.
chestnut_55
Jan 2, 2006 10:04 AM
