Side molding on Fender
wanting to know if the side molding of an integra will fit on the fender of a 91 honda civic hatch? I would like to switch out the pieces cause the integra molding has DOHC engraved in it and would like to be a little bit diff.
I have seen it done it doesnt look right, its not the same height/shape. It might look ok if you replaced the whole side with integra molding. just cut it to size and put it on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxx5905 »</TD></TR><TR><TD CLASS="quote">Just wasnt sure if the tabs on the back of the molding would line up or not. </TD></TR></TABLE>
I would really doubt it. Although if i remember correctly, you can slide the tabs up and down the length of the moulding, so the spacing between the tabs isnt a problem. You might have to change the tabs over to civic tabs though, so they fit.
argetni aruca
Dec 4, 2005 01:17 PM
