Aeromotive A1000 ????????
Old Jan 24, 2008 | 03:03 PM
JBLAZE622's Avatar
Default Aeromotive A1000 ????????
i have an A1000 i'll be using i've heard a few rumors that you need to run a voltage reg. and some ppl say you dont have to just looking for a few more opinions also this car will see the street and track probally a lil more street tho if that matters
Old Jan 24, 2008 | 03:19 PM
Chris99SI's Avatar
Default Re: Aeromotive A1000 ???????? (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">I wound run the regulator just to be safe Trying to get my buddy to do the same on his street A1000</TD></TR></TABLE>
How much do they cost?
Old Jan 24, 2008 | 03:21 PM
1992Si's Avatar
From page 10 in the Aeromotive catalog for the A1000, Billet Pump Speed Controller (P/N 16302) recommended for EFI street duty.
Now if your saying you know more then the people who designed this pump, go ahead and do what you think is best.
After all it's only $400.00 to replace it.
Old Jan 24, 2008 | 03:56 PM
redboost10's Avatar
we have a a1000 fuel pump on a s2000 sandrail. of course, being out on the sand it has continuous use, not just a 1/4 mile pass and off. we dont use the regulator and we arent having any problems.
do i recommend not using it? no
Old Jan 24, 2008 | 04:05 PM
redboost10's Avatar
we usually take it out for a good 45 minutes at a time. im not gonna lie, the pump gets hot. im not sure what the op's plans are, but i personnaly thnk 45 minutes of continuous use is killing that pump...but its fun when your out there.
before we were just running a bosch, but when we switch over to e85 we got the a1000
Old Jan 24, 2008 | 04:07 PM
redboost10's Avatar
the tank on it right now is like a 10 gallon al tank we fabbed up
edit: sorry to steal this thread, im done
Old Jan 24, 2008 | 04:13 PM
redboost10's Avatar
yeah i personally would recomend using it, like i said after 45 minutes or so, that pump is pretty warm. weve been out about 5-6 times now, and so far so good.
Old Jan 24, 2008 | 05:14 PM
DaveF's Avatar
Default Re: Aeromotive A1000 ???????? (redboost10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redboost10 &raquo;</TD></TR><TR><TD CLASS="quote">
edit: sorry to steal this thread, im done </TD></TR></TABLE>
you cant talk about this thing and not post a pic of it. sand rails are just plain bad *** ! i havent seen many nice buggys out here on the East coast, mostly old ******** with vw engines
Old Jan 24, 2008 | 05:21 PM
redboost10's Avatar
Default Re: Aeromotive A1000 ???????? (DaveF)
ill get some pictures tomorrow, at school right now for the week
Old Jan 24, 2008 | 06:00 PM
DaveF's Avatar
see avatar !
ill be expecting those pics !
Old Jan 24, 2008 | 07:05 PM
A train's Avatar
Default Re: Aeromotive A1000 ???????? (JBLAZE622)
whats this pump good for hp wise will it handle 800fwhp? and my bad for asking this im only an a/m guy but we are having problems with the pump we are currently using on our k20turbo setup at around 650!
Old Jan 24, 2008 | 08:24 PM
miller's Avatar
Default Re: Aeromotive A1000 ???????? (A train)
it can handle 800hp. I have never used the voltage regulator in all my years using this pump and have never had an issue with one due to overheating.
Old Jan 24, 2008 | 08:43 PM
tony1's Avatar
Default Re: Aeromotive A1000 ???????? (miller)
About 850whp is where mine started to loose pressure.
Old Jan 24, 2008 | 08:46 PM
miller's Avatar
Default Re: Aeromotive A1000 ???????? (tony1)
yeah tony, i heard that it is crazy when fuel pressure gets loose.
Old Jan 24, 2008 | 08:48 PM
tony1's Avatar
Haha, yeah, i just tightened it up and it was as good as new.
Old Jan 24, 2008 | 09:42 PM
4piston's Avatar
tony how much pressure were you able to achieve up near 800hp?
Old Jan 24, 2008 | 10:36 PM
GodFather of Boost's Avatar
With 1000cc you should be able to get 700whp dynojet. what is your base pressure and max boost pressure. these pumps dont like to go over 80psi.
set base at 40(vac. hose on) and you should be alright.
with 1600cc ive gotten 820whp
PS thanks again tony
Old Jan 25, 2008 | 05:59 AM
JBLAZE622's Avatar
so if i dont run the Reg i should be alright i mean the car is'nt gonna drive more than 30-40 min at a time at the most
Old Jan 25, 2008 | 02:36 PM
h22 civic's Avatar
Default Re: (JBLAZE622)
ive had my pump on the car for about 4-5 years now no regulator and the FACTORY wireing sat in bumper to bumber trafic in 90* weather 2 hour road trips and thousands of miles and ive had zero probs ...when i was first installing the set up i looked at the oem wire and kinda put a schmerk on my face figuring this wont last long .glad i was wrong .........probally go out know and the maddafacker wont work
Old Jan 25, 2008 | 02:42 PM
tony1's Avatar
Default Re: (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">ive had my pump on the car for about 4-5 years now no regulator and the FACTORY wireing </TD></TR></TABLE>
Haha, using the factory wiring on that pump is a voltage regulator in itself!!!
Old Jan 26, 2008 | 07:47 AM
h22 civic's Avatar
Default Re: (tony1)
what imtrying to get at is no AEROMOTIVE REGULATOR and FACTORY GAUGE WIREING
Old Jan 26, 2008 | 08:51 AM
evil_eagle's Avatar
I'm feeding an aeromotive a1000 with 2 walbro 255's. Both walbros are intank coming out in 2 -6an lines to a -6an -6an -8an NOS Y fitting, then the -8an line goes into the aeromotive A1000. I've been able to achieve a bit more pressure out of the A1000 pump this way with absolutely no pressure drop at 45lbs of boost on a gt4202 turbo and had enough fuel to supply a 100shot wet nitrous setup. Fuel pressure was set right at 45psi with the vac off. No voltage reg and I am using 10gauge wire to feed power to it.
Car has gone 159mph and low 9's with the car being at 3000lbs. I think it's safe to say with the pumps setup this way it's supporting around 1000whp.
Pump has been working flawlessly so far (knocks on wood lol)
Although the damn thing sounds like I am being chased by a lawn mower haha.
Old Jan 28, 2008 | 11:45 PM
V-SPEC 1's Avatar
Default Re: (evil_eagle)
Subscribed
Old Jan 29, 2008 | 05:25 AM
EdsGTI's Avatar
Default Re: (V-SPEC 1)
With out a1000 and 1000cc we were loosing too much flow up top, this is 4 bar base and 40psi boost. We needed the boost to make the power, and needed the injector maxed to make the power
I ran this pump for 2.5 years, no controller, no issues ever. 675whp, 465tq was the last power we made with this pump.
We are moving to two 044's and 1600cc injectors.
Old Jan 29, 2008 | 09:55 PM
miller's Avatar
Default Re: (EdsGTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EdsGTI &raquo;</TD></TR><TR><TD CLASS="quote">With out a1000 and 1000cc we were loosing too much flow up top, this is 4 bar base and 40psi boost. We needed the boost to make the power, and needed the injector maxed to make the power
We are moving to two 044's and 1600cc injectors.</TD></TR></TABLE>
leave the pump alone, switch to the 1600's and you will be fine. Ill talk to when you come by the shop but there is no need to change what isnt broke.
