WTB::: EF B series swap parts and CRX stuff
Hey guys i need a long list of stuff so here goes
B series cable 5 spd tranny
90-93 integra clutch cable
DA integra 5 spd axles and intermediate shaft
hassport or knockoff crx b series swap shift linkage
any crx b series motor mount set
obd 0 b18 distributor (non vtec)
obd0 ls 5 spd ecu
b series starter
b18c1 eagle h beam rods or other high end brand (used ok)
b18c1 forged low comp 81mm piston set high end brands only (used ok)
crx track bar
crx headlights both sides with brackets
MINT crx fenders driver and passanger side (fiberglass ok)
crx ZC hood MINT. ( the one with the little bump)
crx rear hatch lift supports
lightweight b series flywheel
assorted b18c1 or b18b gaskets (new fel pro only lol)
acl race bearing set for b18c1 set or other high end brand( new only lol)
spark plug wire set for b18b
integra brake master cylinder
b series TYPE R ONLY oil pump (used ok)
please email me directly at Bigbadtim1137@aol.com for a response within 12 hours. Alot of these parts I am willing to pay high for simply because im sick of looking for parts
Modified by 90Rexx at 4:23 PM 1/24/2008
obd0 ls 5 spd ecu
b series starter
crx track bar
what brand r those swap mounts cuz 100 is pretty steep unless they r avid or hassport but yah def interested. and what tranny cable r u talking about for a crx? i need a b series clutch cable. and ill take the ecu for 35 bucks regardless. please email me at bigbadtim1137@aol.com so we can get this rollin cuz im not on forums too often.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90Rexx »</TD></TR><TR><TD CLASS="quote">what brand r those swap mounts cuz 100 is pretty steep unless they r avid or hassport</TD></TR></TABLE>
on what planet is 100 bucks steep for ef swap mounts... ?
i have a couple obd1 ls ecus
i have the starter, dizzy, and ecu if u still need it..also have a act 8lb flywheel and ls cable tranny but that is still in the car(so i u need them might take awhile to get out)...i basically have a ls swap into a 89 hatch that im taking out for a built d series, so if u need anything else LMK
also have the motor mounts, axles and shift linkage too..but like i say the swap is still in my car and im not in a hurry to take them out so all the ez stuff like dizzy and what not i can get to u ASAP but other stuff will be when i have time
mwasnp
14
Mar 2, 2003 03:58 PM
