Removing rear deck in a Coupe- Effect stability?
Old Jan 24, 2008 | 02:12 PM
2fastGSR's Avatar
King of the One Liners
Default Removing rear deck in a Coupe- Effect stability?
So I want to start removing some of the excess weight in my 95 coupe. It will be a dedicated track car.
I know i have been told in the past that in most rear wheel drive cars that the rear deck plays a big part in chassis stability. Just wondering that in the case of the coupe will removing it result in any negative effects like this ?
thanks in advance
Old Jan 25, 2008 | 12:11 AM
quicksilver1689's Avatar
i ♥ snails
i wouldn't remove it personally, helps tie the rear together from torsional movement is what im visualizing in my head. Is it worth a few pounds to trade chassis strength/integrity?
Old Jan 25, 2008 | 05:19 PM
slacks's Avatar
Default Re: Removing rear deck in a Coupe- Effect stability? (2fastGSR)
if you get rid of it can i have it
Old Jan 26, 2008 | 08:40 AM
King V's Avatar
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">i wouldn't remove it personally, helps tie the rear together from torsional movement is what im visualizing in my head. Is it worth a few pounds to trade chassis strength/integrity? </TD></TR></TABLE>
Its called a "torque box", to use the body shop term. The firewall, floorpan, A, B, and C pillars and the roof all have to be in place, unless you like driving a wet dishrag. Removing the rear deck would be like climbing a ladder with one or two rungs missing. You can still climb the ladder, but would you really trust it?
Old Jan 26, 2008 | 03:54 PM
2fastGSR's Avatar
Default Re: (King V)
thats what I wanted to know. thanks !
Old Jan 28, 2008 | 10:21 AM
King V's Avatar
Default Re: (2fastGSR)
....although if you get creative with carbon fiber and some epoxy resin........
m2s4drespecial
Honda Civic (2001 - 2005)
Sep 7, 2007 10:32 PM
MidwestSi
Sep 29, 2005 06:56 AM
Civic44
Jun 10, 2005 07:06 PM
