Brage Upgrade Confusion???
Old Jan 24, 2008 | 01:41 PM
Si-Samuri's Avatar
Default Brake Upgrade Confusion???
I have searched threads and I am still confused. I want to do a front brake upgrade on my 90 DX. Will a DA front brake assembely bolt directly in?? What problems will I run into or what parts can I use/ not use?? We all know its hard to find and EX front set-up.
Modified by Si-Samuri at 11:34 AM 1/27/2008
Old Jan 24, 2008 | 03:05 PM
Crx Jimmy's Avatar
Default Re: Brage Upgrade Confusion??? (Si-Samuri)
Yes the da bolt right in, just use your civic/crx upper control arms
Old Jan 24, 2008 | 03:09 PM
zccr-xsi's Avatar
u could also upgrade to a teg mastercylinder and brake booster.
Old Jan 24, 2008 | 07:25 PM
Si-Samuri's Avatar
OK sounds great. thanks for the help.
Old Jan 24, 2008 | 07:27 PM
Si-Samuri's Avatar
Are they similar to the EX and Si set-up.
Old Jan 25, 2008 | 06:20 AM
zccr-xsi's Avatar
yea u can use teg front brakes but i think u may have to use the si lca.u might want to double check look in the ef F&Q to be sure.
Old Jan 27, 2008 | 08:40 AM
Si-Samuri's Avatar
I already have skunk2 Lca's which im sure are more similar to the si.
Old Jan 27, 2008 | 04:38 PM
scuzz's Avatar
Default Re: (Si-Samuri)
I used 93 teg brakes/knuckles on my 88 CRX with a 90 EX 15/16 master cylinder.
Old Jan 28, 2008 | 06:18 AM
Si-Samuri's Avatar
Do you guys know if any parts of a DC integra(92-00), specifically an LS will work.
Old Jan 28, 2008 | 09:06 AM
zccr-xsi's Avatar
i know u can use gsr brake set-up
Old Jan 28, 2008 | 09:50 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si-Samuri &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys know if any parts of a DC integra(92-00), specifically an LS will work.</TD></TR></TABLE>
Yes, they are all the same size.
You can even use 94-00 Integra Brake components onto 90-93 Integra knuckles to make them fit on your Civic. That is what I did with my 88 CRX.
Also, the 90-91 Civic EX does have the same size brakes as the Integra. The only difference is the Upper Control arms and the knuckle.
Old Jan 28, 2008 | 10:22 AM
akandok's Avatar
I just swapped some GSR brakes in my CRX. Then I started reading about it..
The problem that I am having is that I have to much positive camper now.. and on one web site it says you get positive caster as well.
I measured the bolts on the brake caliper braket and they are both 14mm apart. So the integra calipers and disks should bolt on to your existing knuckle.. I cant confirm yet because I have not done it yet.. But I will let you know as soon as I get it done
Old Jan 28, 2008 | 10:42 AM
EL Vap133's Avatar
Default Re: (akandok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akandok &raquo;</TD></TR><TR><TD CLASS="quote">I just swapped some GSR brakes in my CRX. Then I started reading about it..
I measured the bolts on the brake caliper braket and they are both 14mm apart. So the integra calipers and disks should bolt on to your existing knuckle.. I cant confirm yet because I have not done it yet.. But I will let you know as soon as I get it done</TD></TR></TABLE>
They will not bolt up to the 88-91 knuckles (unless it is the 90-91 EX). It might be possible to make them fit but you will need to custom make some mods. What mods, I am not sure.
Old Jan 29, 2008 | 11:30 AM
Si-Samuri's Avatar
definitely keep me updated.
Old Jan 29, 2008 | 11:32 AM
Si-Samuri's Avatar
What about the DC rear trailing Arms?? will these fit??
Old Jan 29, 2008 | 02:42 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si-Samuri &raquo;</TD></TR><TR><TD CLASS="quote">What about the DC rear trailing Arms?? will these fit??</TD></TR></TABLE>
Yes, any 88-00 (Civic, CRX, Integra) Rear trailing arms will fit.
Old Feb 17, 2008 | 05:55 PM
Si-Samuri's Avatar
Default Re: (EL Vap133)
So I can't use my factory DX knuckles or the DC integra ones?? I was wondering id the splines would match up.
Old Feb 18, 2008 | 07:50 AM
Si-Samuri's Avatar
And if i want to go b-series don't i need different knuckles.
Skulinn
Apr 21, 2011 12:21 PM
cardudelude
Nov 15, 2010 05:42 AM
coot_er
17
Jan 27, 2007 11:22 AM
jisu009
10
Jul 30, 2003 06:39 PM
litlekikr
Dec 24, 2002 12:24 PM
