Fixing this passenger side corner hit on a 94 teg (pics inside)
Old Jan 24, 2008 | 01:05 PM
Sinner's Avatar
Default Fixing this passenger side corner hit on a 94 teg (pics inside)
Anyone have any tips or hints on how to pull this out?
how can I pull out that corner of the unibody? do I bang it out or pull it out? Any ideas would be great.
Thanks
Nick
Old Jan 24, 2008 | 01:38 PM
VTEC_PRODUCTION's Avatar
Default Re: Fixing this passenger side corner hit on a 94 teg (Sinner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have any tips or hints on how to pull this out?
Thanks
Nick</TD></TR></TABLE>
its not worth pulling it out my man...you will spend all day doing it and it will never be "just right" my suggestion is cut and weld. find a donor car preferable one that was rear ended of hit on the side or other side front and measure, measure again, cut, measure, cut, weld. with those steps you cant go wrong
Old Jan 24, 2008 | 02:12 PM
Disease's Avatar
Default Re: Fixing this passenger side corner hit on a 94 teg (VTEC_PRODUCTION)
Car needs to go on a frame machine. Get measured and pulled. Then cut out the headlight pocket and upper rad support and inner appron. The upper fender rail may be salvaged. the rest needs to be replaced. Check for sway just by looking at your radiator since your hood is definately damaged. Check to see that the tabs are not broken. If they are then you most likely have a sway wich I think you do. Usually on these cars if the radiator tabs that guide it into the hold down are broken it means the rad support has been pushed over. Check your driver side door gap as well. If it closed up then that is another sign as well.
Old Jan 24, 2008 | 02:35 PM
Sinner's Avatar
great info... this car might end up just being an engine donar car for my other get
hip_hop_s0ulchild
Sep 26, 2008 09:04 AM
RHD DA6
Aug 23, 2007 04:21 PM
MF Doom
Feb 2, 2006 02:34 PM
Chubakon
Jul 25, 2004 12:33 PM
gulf imports
Jan 20, 2004 12:39 AM
