ecu or timing problem??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killafred187 »</TD></TR><TR><TD CLASS="quote">i swapred it into a 91 si hb only thin done to it and o yeah forgot to tell you guys ima noob</TD></TR></TABLE>
Well, that's pretty obvious.
You still didn't answer all of my questions yet, chief.
Does the block just have "D15B" stamped on it? VTEC valve cover?
How did you convert to OBD1? Did you use a jumper harness? What ECU are you using?
Any CELs?
Any CELs?
So is your car a 91 or 89? you gave two different years in two different posts. The codes would be:
(6) ECT - water temperature sensor
(10) IAT - intake air temperature sensor
(22) VTEC pressure valve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DailyDriverCivic »</TD></TR><TR><TD CLASS="quote">So is your car a 91 or 89? you gave two different years in two different posts. The codes would be:
Well, there you have it. You screwed up the wiring, and apparently you have VTEC.
Fix these codes and see if your problem goes away.
You'll need to get a service manual then check the sensors and the wiring going to them.
LorenGeist
12
Oct 6, 2004 06:30 AM
