Gearbox-help
Old Jan 24, 2008 | 11:21 AM
Dzem's Avatar
Default Gearbox-help
Hi, I have Honda crx II, D16A8 with serial gear-box, but I need shorter gear-box.(better acceleration-for races). Could I use some of gearbox from Civic 4g??? I donīt know if gear-boxes are interchangeable. And I donīt know type of shorter gearbox.
If anybody know it please help me.
Thaks for your help.
Old Jan 24, 2008 | 12:00 PM
wiZCo's Avatar
Stouts 'n' Scotch
You can try to use a USDM-spec Si (L3) trans or just doing a final drive swap from that transmission (easier/cheaper). I think that may come from the 1.6i models in the non-US markets.
Maybe somebody else can help, I'm not 100% sure that your trans is the same as the JDM-spec one, so that may be an option as well.
I assume that you have the stock transmission on right now?
P.S. For your info, you may hear people refer to your engine as a DOHC ZC, that's the Japanese equivalent, they're almost exactly alike.
Old Jan 24, 2008 | 03:15 PM
Crx Jimmy's Avatar
Default Re: (wiZCo)
Yes it looks like you have a zc engine. the best would be a zc transmission with a si final drive for short gears
krysted9354
14
May 23, 2009 09:04 PM
Modern91Hatch
Apr 25, 2008 08:38 AM
U5EL355
Oct 18, 2006 08:55 AM
Zager
Jun 28, 2002 12:15 PM
Mugen_R
Oct 16, 2001 06:36 PM
