IACV and VTEC plug switched and now car wont start
Old Jan 24, 2008 | 10:50 AM
x4thGenCafe's Avatar
OF THE KINGS
Default IACV and VTEC plug switched and now car wont start
I had a friend tell me my IACV and VTEC plug might have beeen misplaced and that might be the cause of me not having vtec engage on my obd0 B16A.
So i switched the two plugs and ran it and still drove the same with no vtec and still idled low so i out them back to how they originally were and I go to leave for work and it wont crank over fully. Its wanting to start but not run.
Anyone ?
Old Jan 24, 2008 | 10:56 AM
ef-hatchcrap's Avatar
Default Re: IACV and VTEC plug switched and now car wont start (x4thGenCafe)
Reset the ecu disconect the battery for 3 mins then try
Old Jan 24, 2008 | 11:13 AM
OF THE KINGS
Default Re: IACV and VTEC plug switched and now car wont start (ef-hatchcrap)
i reset it twice and got nothing
Old Jan 24, 2008 | 12:08 PM
OF THE KINGS
Also . . My fuel pump isnt priming anymore and the Check Engine Light doesnt turn off after like the 2 seconds it takes for the pump to prime
Old Jan 24, 2008 | 12:20 PM
HiProfile's Avatar
Chances are your ECU is dead now. Most people burn out a circuit when they swap IAT and IACV plugs, but I'm unsure about VTEC. Also, on you for not using a continuity tester. You NEVER use trial and error when it comes to wiring and an ECU.
I'd suggest starting it with the gas pedal pressed a little to compensate for a broken IACV, or turn the idle screw out a few turns. Otherwise try a different ECU...
Old Jan 24, 2008 | 12:24 PM
OF THE KINGS
would there be any chance its my main relay or are you positive its the ecu ?
Old Jan 24, 2008 | 01:33 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (x4thGenCafe)
check the ECU itself, if the blinking LED is solid red and not blinking, its a good chance your ECU is bad
Old Jan 24, 2008 | 02:11 PM
OF THE KINGS
Default Re: (HondaPartsHero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero &raquo;</TD></TR><TR><TD CLASS="quote">check the ECU itself, if the blinking LED is solid red and not blinking, its a good chance your ECU is bad</TD></TR></TABLE>
my ecu wont even light up.
it usually throws code 9 and 14
Old Jan 24, 2008 | 05:37 PM
OF THE KINGS
Old Jan 24, 2008 | 05:47 PM
D50boy's Avatar
Pray it's a fuse.
Old Jan 24, 2008 | 06:04 PM
OF THE KINGS
Default Re: (D50boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D50boy &raquo;</TD></TR><TR><TD CLASS="quote">Pray it's a fuse. </TD></TR></TABLE>
i should probably check
Old Jan 24, 2008 | 07:37 PM
OF THE KINGS
still nothin
Old Jan 25, 2008 | 03:04 AM
killa rex's Avatar
Main relay
Old Jan 25, 2008 | 04:38 AM
Technical Hero
Default Re: (killa rex)
try another good ecu and see if that fixes it
Old Jan 25, 2008 | 06:50 AM
OF THE KINGS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero &raquo;</TD></TR><TR><TD CLASS="quote">try another good ecu and see if that fixes it</TD></TR></TABLE>
ive been trying to do this but theres only one other kid in this town with an obd0 b16 and hes not really tryin to come over . .
this stinks
Old Jan 25, 2008 | 08:32 AM
OF THE KINGS
my friend tried my ECU and it works fine on his hatch.
im taking it that my ECU is good right ?
haa
main relay for the next suspect ??
Old Jan 25, 2008 | 09:26 AM
MoonScryer's Avatar
Yes.
Old Jan 26, 2008 | 08:38 PM
OF THE KINGS
Just got a new main relay and the fuel pump still wont prime and the car still will not start . .
im running out of ideas
you guys have anymore suggestions ?
thanksss
Old Jan 26, 2008 | 11:02 PM
pandarex's Avatar
you checked all the fuses? under dash and under hood?
and the ecu wont blink when you tuen the ignition on?
Old Jan 27, 2008 | 06:17 AM
OF THE KINGS
Default Re: (pandarex)
Got it. Fuse 14
Modified by x4thGenCafe at 8:23 AM 1/27/2008
Hanmin
Mar 14, 2012 03:45 PM
squeeks
11
Mar 8, 2008 04:49 PM
turboeg831
Oct 20, 2006 09:50 AM
0bLiViOuS
14
Jan 19, 2006 07:17 AM
HamiltonRex
Nov 28, 2005 09:53 PM
