HELP: car died while idling and wont start up anymore
Old Jan 24, 2008 | 10:12 AM
cilvia's Avatar
Default HELP: car died while idling and wont start up anymore
so my car died while it was idling at stop...tried to start up but battery seemed to be low cause i heard low power cranking...got someone to jump me but it would crank but not fire up...gas is 3/4 full...would could this problem be??
Old Jan 24, 2008 | 10:21 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: HELP: car died while idling and wont start up anymore (cilvia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cilvia &raquo;</TD></TR><TR><TD CLASS="quote">so my car died while it was idling at stop...tried to start up but battery seemed to be low cause i heard low power cranking...got someone to jump me but it would crank but not fire up...gas is 3/4 full...would could this problem be??</TD></TR></TABLE>
HAH!! My stupid EM1 died the same way. It's most likely a distributor. this happens a lot on hondas.
check for spark. Use a spark tester or screwdriver. take off one of the plug wires and ground it out (using the spark tester or screwdriver). Spark tester is more accurate, as you can get a gap to test.
Have someone crank the car and watch for spark.
If the battery is dead, jump the car and then crank it.
If there is no spark, you have a distributor issue. I just bought a brand new distributor from ebay for $128 shipped. So dont get ripped off and pay $4-500.
Before you do all this, make sure your fuel pump is priming. When you crank, you should be able to smell fumes of unburnt gas.
Is it cranking normal...or does it seem like there's no resistance?
Datphan's Avatar
seems like you put more load then your battery can handle. check the voltage drop of your battery while cranking. shouldnt drop below 9.6v.
Old Jan 24, 2008 | 10:41 AM
delslow05's Avatar
Default Re: HELP: car died while idling and wont start up anymore (Datphan)
i had the same problem on my delsol it was distributor problems. i took the cap off and tightin down all the wires on the inside and havent had a problem since.
Old Jan 24, 2008 | 12:03 PM
lv6l's Avatar
igniter or coil in the distributor. or both.
civic2sick
Feb 26, 2020 09:39 PM
MRQ
Honda Civic (2006 - 2015)
Jun 9, 2019 05:48 AM
khoalizzle
Sep 10, 2008 10:51 AM
civic92si
Mar 29, 2007 08:28 PM
baboonstyle
36
Nov 13, 2005 01:24 PM
