bigger throttle body for the d16a6 intake manifold ?
Old Jan 24, 2008 | 06:28 AM
ProjetEF's Avatar
Default bigger throttle body for the d16a6 intake manifold ?
Hi everyone !!
I would like to know if there is any throttle body from another honda or aftermarket that is bigger than 55mm(OEM) and fit on the D16a6 intake manifold ?
thanks a lot !
Old Jan 24, 2008 | 12:57 PM
ProjetEF's Avatar
No body know ???
Old Jan 24, 2008 | 01:03 PM
dr_latino999's Avatar
Default Re: (ProjetEF)
The A6 manifold has an independent bolt pattern, so no other OEM TB's would bolt on. If you're stuck with the stock manifold, you can bore out the TB.
Old Jan 24, 2008 | 03:39 PM
ProjetEF's Avatar
Default Re: (dr_latino999)
Thanks a lot, thats exactly what i was wondering to know !!!
Old Jan 24, 2008 | 06:55 PM
whiteknightef's Avatar
i thought a b16 or b-series TB fit? Im running an after market one on my z6 manifold, and I know mine fits the b-series as well. I used my a6 one for a while on there too.
Old Jan 24, 2008 | 06:58 PM
andrey320's Avatar
rc engineering made (makes?) or modifyes yhe stock one. I've got one laying around. Haven't decided whether to install it or not....
Old Jan 24, 2008 | 07:05 PM
StorminMatt's Avatar
Default Re: bigger throttle body for the d16a6 intake manifold ? (ProjetEF)
You can certainly get a larger throttle body. BUT, whether it will REALLY be beneficial is another matter altogether. Honestly, if your motor is bone-stock, you would be better off spending the ~$200 elsewhere.
Old Jan 24, 2008 | 08:01 PM
nitewolf's Avatar
Default Re: bigger throttle body for the d16a6 intake manifold ? (StorminMatt)
dbh series tb have the same bolt pattern i got a b20 tb on mi y8im port matched noticed a power gain threw mid and top end
Old Jan 25, 2008 | 05:15 AM
Default Re: bigger throttle body for the d16a6 intake manifold ? (nitewolf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteknightef &raquo;</TD></TR><TR><TD CLASS="quote">i thought a b16 or b-series TB fit? Im running an after market one on my z6 manifold, and I know mine fits the b-series as well. I used my a6 one for a while on there too.</TD></TR></TABLE> Every other D-series manifold after the A6 (until 2000) is compatible with the other throttle bodies.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitewolf &raquo;</TD></TR><TR><TD CLASS="quote">dbh series tb have the same bolt pattern i got a b20 tb on mi y8im port matched noticed a power gain threw mid and top end</TD></TR></TABLE> D/B/H have the same pattern up to an extent. And it's nice to know your butt dyno results.
shahriar35
Jan 31, 2010 12:13 AM
jnasty
Nov 16, 2006 03:24 PM
lmiguelvv
31
Aug 29, 2005 05:25 PM
Vera
Nov 22, 2003 09:17 PM
goula SOS
Jun 24, 2003 02:53 PM
