Ground Post
I have a 1990 Accord EX, and I'm having problems with the amps for my subwoofers. I can't seem to find a good ground connection anywhere in the trunk that has a big enough nut to hold an 8 AWG ground wire.
Anyone else with this body style have any input on where I could find a good place for a ground?
Yep.
Look at the rear seat area - where they fold down you should be able to see the metal under neath the carpet a bit, I've seen quite a few there, if you really can't find one.
Drill + self tapping bolt
You're obviously going to have to take out some of the carpeting to find a bolt to ground to. I ran mine into the cabin and used the bolt that holds the spool for the rear seatbelt.
