what do you think i will run?
88 CRX HF Stock
+ Ls/Vtec Swap
+ Skunk2 Stage 2 Cams
+ Skunk2 Manifold
+ ITR .25 mm Pistons
+ ITR Oil Pump
+ AEM Cam Gears
+ AEM Fuel Rail
+ DC Sports Stainless Header
+ YS1 LSD Cable Tranny
+ PR3 Skunk2 Chiped ECU
What do you think i will run in 1/4 miles?
Anything else I should add to run under 13 sec?
+ Ls/Vtec Swap
+ Skunk2 Manifold
+ ITR Oil Pump
+ AEM Cam Gears
+ AEM Fuel Rail
straight lines *yawn*
I actually have no idea, thats a pretty nice setup, since it is an hf I would guess mid to low 13's. With slicks you might possibly hit 12's, also depends alot on how good of a driver you are.
[Modified by Krow, 5:53 AM 7/2/2002]
Low 13's easy, 12's are definitely possible. A friend of mine with a stock LS motor and tranny with bolt-ons runs 14.0's- 13.9's on slicks in his HF... (22x8-13 M&H's on Lenso's for reference purposes)
Pythagoras
29
May 22, 2007 07:12 PM
